Just rebuilt/replaced just about EVERYTHING in the suspension of my '90 XR7. I used a set of used Eibach springs sourced from a member here. I did not measure ride height before, with the broken pigtail stock springs I also changed to 18's with 245/45 s at all 4 corners (slightly shorter than stock 225/60-16's). I made sure to tighten everything with weight on the suspension, but it still sits like a 4X4. Does Eibach make a stock ride replacement spring for SC/cougars?
I have the factory manual with stock alignment specs. Is there anything that needs to be to a different spec on a lowered car? My priority's are 1 tire life/wear, 2 performance, 3 road noise, in that order.
Thanks
Adam
Thanks
Adam
