Results 1 to 6 of 6
Thread: Engine Bogg after FMIC install
    Apr 2008
    Vallejo, CA
    59
    After installing the FMIC I am having and issue when giving moderate to heavy throttle the engine chokes out from a idle, and low speed acceleration. The piping runs out of the blower down between the engine/radiator, around the front, then connects into the intake side (a lot of piping). Sooo, I'm pretty sure when the bypass valve shuts the engine is robbed of air due to how long the air has to travel. No other issues besides this, and it did not do this with the stock set up. Has anyone experienced this, and come up with a solution? The only thing I can think of to fix this is to some how limit the bypass valve from closing so quickly.
    Douglass
    Jul 2004
    Hamilton NJ
    1,997
    Major vacuum leak
    Sounds like a vacuum leak, the bypass stays open til you floor it and boost kicks in and closes the bypass, its suppose to close during boost. If its closing during idle I would say that the bypass valve is bad, but it would still run.
    Check your vac/boost guage at idle it should be around 17-20 vac
    Tom Downs-member#2752
    RIP Rexy boy!!!! Miss my dog 2006-2018
    5,143
    Sounds like a vacuum leak to me too or it needs a retune or something changed with the fueling.
    SCARlit on drag duty now
    Apr 2008
    Vallejo, CA
    59
    I think I may have described it wrong. Lets say I am idling, Looking at the engine and giving gas to the throttle body by hand. Scenario one: If I ease into the throttle, then go WOT it is fine. I can see the bypass valve working. Scenario two: From idle, if I go WOT I can see the Bypass valve close instantly, stay closed, and the engine boggs down (almost sounds like shutting off the engine).
    Vacuum at idle is good, and Boost is solid 10-11psi.
    6,538
    Trying to imagine how you can have boost and it falls flat at the same time...
    About scenario 2 - when you do that, can you see all the rubber couplers to confirm none have collapsed/split/blown off?
    Any photos of the plumbing you can share?
    Apr 2008
    Vallejo, CA
    59
    Good Point, I'll see what the boost/fuel ratio is when it happens.
    From what I can see everything looks good, and seems to be operating correctly on the valve
    Here is the best picture I have at the moment. The piping wraps around the front continues around the left side, then back into the factory inter-cooler pipe.
