Results 1 to 8 of 8
Thread: Fixed problem
    May 2004
    Marlton, NJ
    148
    Fixed problem
    Finally after taking off the winter i started looked at my issue regarding the check engine light and tach. Well I found the problem and wanted to pass on.It was the wire behind the fuel pressure regulator that was broken. A simple fix that drove many people just hit cured now runs great. Wanted to pass this on.
    6,538
    Quote Originally Posted by 90redsc View Post
    Interesting - we've been told that wire is a ground for the O2 sensors, so I can imagine it throwing a CEL. I don't suppose there were any codes, tho?
    Thanks for the followup.
    May 2004
    Marlton, NJ
    148
    Yes code when warmed up was running too lean.
    May 2004
    Marlton, NJ
    148
    The tech now functions normal also
    6,538
    What was it doing when it didn't function normally? Dead, or dancing, or....?
    May 2004
    Marlton, NJ
    148
    Dancing around then would stop
    6,538
    Usually cam sensor/harness issues in that case, but if your work made it behave, it's all good.
    May 2004
    Marlton, NJ
    148
    Yep replaced many parts. But works now.
