Results 1 to 4 of 4
Thread: Cooling fan problems on 95 SC
    Jun 2018
    Rapid City South Dakota
    5
    My buddy has a 95 SC that seems to be having strange problems for his highspeed pull fan. If the car sits and idles only the low speed fan will kick on and the car's temperature will continue to climb non stop. If you give the car just a little bit of throttle input the high speed fan will then kick on. We adjusted the idle screw a little bit and the fan then kicked on a bit but then the car would idle at 1200 or so at times. It seems that it has to be above 1000 rpm for the fan to be running for some reason.
    He already replaced the fan relays, the fan motor, the ect sensor because of the car trying to overheat at stoplights but when driving down the road its fine. Yesterday is when we noticed the fan only coming on with increased idle. What could cause this?
    6,538
    Do all the fans/speeds self-test ok? Any codes?
    Jun 2018
    5
    The fans test ok it just needs an increased idle to stay on. The push fan runs constantly just the pull fan will not come on. No codes that I am aware of.
    405
    Good evening
    I would do the following:
    Check the condenser fins. Bent fins will be a cause of insufficient airflow to the radiator. A radiator comb is required.
    https://www.youtube.com/watch?v=olMJEAnEBvo
    Check the isolation foam between the condenser and radiator for serviceability.
    Do a coolant pressure test.
    https://www.youtube.com/watch?v=K5p-G3UDi-A
    If the above are OK remove the radiator and take it to a pro radiator repair shop to have it checked out.
    https://www.youtube.com/watch?v=yb03DB97vas
  1. Low Coolant Sensor Problem on '95 SC
    By ezgoing in forum Technical Forum
    Last Post: 03-10-2004, 06:58 PM
  2. Cooling fan quit on me
    By derekhay316 in forum Technical Forum
    Last Post: 08-22-2003, 06:14 AM
  3. Engine Cooling Fan Problem?
    By studpike in forum Technical Forum
    Last Post: 05-07-2003, 03:25 AM
  4. ?'s about EEC Tuners or Chips on 95 SC
    By Robert Kohlman in forum Technical Forum
    Last Post: 04-16-2003, 02:36 AM
