When I first got my SC it was running rough and had a leaking valve cover gasket on the driver side, I have since replaced both valve cover gasket‘s, I have also replaced all the spark plugs, spark plug wires, also a new ignition coil pack. After that I started it and it ran good cold but as soon as it would start to warm up about 5 minutes,it would run really rough and the engine would shake and it would almost die if I gave it throttle it Would idle up but sputter,After this I replaced the DIS module. That didn’t fix it so I replaced the IAC sensor, the ECT sensor, that didn’t work same result, so I replaced the cam sensor, the MAF sensor, that didn’t work either, so I replaced both O2 sensors. That still didn’t fix it and now it doesn’t even want to stay running When I start it dead cold it will start then instantly die if I push on the throttle it will idle up and sputter a lot as soon as I let go of the Throttle it dies. Oh I also replaced the fuel filter and the fuel pump.
Any and all help is greatly appreciated !
Thank you.
Thank you.
