Results 1 to 9 of 9
Thread: Wiper Motor issue..
    Aug 2004
    Canada
    256
    Wiper Motor issue..
    It all started after I had to removed the whole wiper/motor assembly to replace the ABS Accumulator ball. The issue is the wiper will not return to home position. It would stop straight up on towards the driver's side. It's almost like it is running backwards.. but I couldn't find anything that might of got switched around backwards. Any help on that is appreciated.
    Thanks in advance
    Pacific Rim
    6,727
    Well...hummm...did you index the wipers when you put them back on the posts? Are the plastic keys still involved?
    Aug 2004
    Canada
    256
    Thanks for the reply. I went back and swap the piece that goes on the motor shaft around 180 degree which cranks the wiper mechanism. and it is back to normal. Its one piece that I over looked.
    Pacific Rim
    6,727
    Quote Originally Posted by JOE91SC View Post
    I went back and swap the piece that goes on the motor shaft around 180 degree which cranks the wiper mechanism..
    When I get in that far, I just remove the whole assembly and leave that part attached. Glad you sorted it. Good luck w/the repair. Did you see my write up on swapping accumulators?
    Aug 2004
    Canada
    256
    Yes, I sure did. It was very thorough. Thanks!
    Even though I changed the accumulator ball, but the ABS light still stayed on.
    4,404
    You can pull codes on the ABS computer too (separate connector in the trunk on early SC's...red in either case)
    IIRC, the light flashes the codes too.
    Pacific Rim
    6,727
    ...the ABS light still stayed on.
    Quoting myself from a recent thread:
    Most common:
    - accumulator
    - relay(s)
    - brake pressure switch
    - failed ABS pump motor
    - multi-wire ignition switch down on right side of steering column
    See: http://www.sccoia.org/articles/anti-...raking-system/
    Aug 2004
    Canada
    256
    Just curious how is it done? or to get the light to flash code.. I have a OBD1, and I've borrowed an OBD-2. and seems they both don't do ABS codes.
    Pacific Rim
    6,727
    See this link for the manual process using a jumper wire: https://www.f150forum.com/f10/how-re...es-obdi-10907/
  1. Whinning wiper motor
    By saboveed in forum Technical Forum
    Last Post: 11-09-2008, 08:39 PM
  2. Wiper Motor Needed...and headlight flashing issue.
    By sumzxr7 in forum Super Coupe Club of Ontario
    Last Post: 10-21-2004, 03:25 PM
  3. a little help? (wiper motor configuration
    By ottochaus in forum Technical Forum
    Last Post: 11-18-2002, 03:18 AM
  4. wiper motor or wiper switch
    By pipecraze in forum Technical Forum
    Last Post: 08-25-2002, 10:56 PM
  5. Wiper Motor Needed
    By Distinguished Dat2k1 in forum Super Coupe Club of Ontario
    Last Post: 04-13-2002, 09:28 PM
