Results 1 to 8 of 8
Thread: climate control pressure switch bursts
    Jun 2011
    San Diego
    415
    After the AC was figured out I decide to put the car on jackstands last weekend to swap gtp rotor pack change oil,spark plugs, pull and inspect harness etc. I walk out today and see a oil puddle. Pop the hood and new AutoZone pressure switch burst and pissed out the oil..is this just bad luck or could I have done something way wrong.
    --L.Figueroa
    Oct 2004
    Hudson, WI
    168
    What was the part number of the switch ??
    Jun 2011
    San Diego
    415
    Quote Originally Posted by terralex View Post
    I'm not in front of it but this must be it
    https://www.autozone.com/cooling-hea...75015_115711_0
    --L.Figueroa
    PNW/MWV
    6,639
    If there were a scenario that would blow out a serviceable switch, I'd expect something else would give out first - I'd assume the switch was bad from the start, and see if you can warranty it. I know that means risking a repeat, but it's hard to imagine it was good and just gave out.
    Did it just burst/rupture like a hand grenade? Have you removed it and inspected?
    Might it just be the o-ring? What color was the new one? Any chance the old one stayed and the new switch meant they were doubled up?
    Jun 2011
    San Diego
    415
    I didnít grenade. More like a leak through the top. Kind of like when an oil sender unit starts leaking but this seem a little more violent with oil splattered on the hood and engine compartment
    --L.Figueroa
    Jun 2011
    San Diego
    415
    --L.Figueroa
    PNW/MWV
    6,639
    Ah, I see, thanks.
    Yep, sounds like you just had bad luck w/that one. If you can warranty it, it'd be nice if they'd pay for the wasted consumables, too, tho I doubt that will happen.
    Jun 2011
    San Diego
    415
    Ah, I see, thanks.
    Sounds good. Iíll try and return it. I Will not be denied AC this summer!!!
    --L.Figueroa
  1. Climate Control switch
    By 90sc35thann in forum Parts for Sale
    Last Post: 07-24-2013, 09:37 PM
  2. Climate Control switch
    Last Post: 07-24-2013, 03:11 PM
  3. Replies: 15
    Last Post: 06-22-2009, 06:44 PM
  4. question about auto climate control...
    By sc steve in forum Technical Forum
    Last Post: 07-19-2002, 08:58 PM
  5. swapping for auto climate control
    By kevin898 in forum Super Coupe Club of Ontario
    Last Post: 02-23-2002, 06:38 AM
