Results 1 to 3 of 3
Thread: update on fan
    Oct 2012
    35
    update on fan
    Thanks to KMT i found the fusible link for the fan and fixed. Here is what I have,
    Pulled fan and verified both LS and HS fan work
    ran engine and pulled ECT, fan on, replace ECT fan off.
    Got codes 51, from what I read, LS and HS fan come on quick during test. They did
    Replace ECT no LS fan however, I recall that the thermostat is 180 and have not flushed cooling system for a while,
    My plan was to flush system and replace thermostat with 195.
    Does anyone agree that would be a good next move?
    Thanks again to KMT for all the help.
    Jim
    PNW/MWV
    6,639
    Unless you have a chip and can set fan turn-on manually, only use stock 195 thermostat. Try to find one w/a bleed hole.
    Are you comfortable with the correct fill/air bleed process for getting air out of the cooling system when refilling?
    Is the radiator cap new and 16 lb?
    Is the chin spoiler, and skirt below/behind the radiator, in place?
    May 2004
    Marlton, NJ
    160
    J am familiar with the air bleed process.
    However the skirt is missing,it rotted away sometime ago. Will need to replace.
    I will also get a new rad cap . The star will be as you suggest.
  1. Updates on car
    By 91 XR7 in forum Super Coupe Club of Western Canada
    Last Post: 06-01-2002, 07:03 PM
  2. Update on my SC motor buildup
    Last Post: 05-08-2002, 01:00 AM
  3. An update on my situation for those who have followed me
    By white91sc in forum Non Technical Forum
    Last Post: 05-03-2002, 11:26 PM
  4. Update on my shifter
    By Dan Lineback in forum Super Coupe Club of the Southeast
    Last Post: 01-29-2001, 10:08 PM
