Results 1 to 7 of 7
Thread: Tilt steering malfunction
    Jan 2015
    Tidewater area, Virginia
    240
    I just noticed that my tilt steering column does not lock. I'm short, so I like the steering wheel all the way down, but without pulling the locking lever I can easily lift the column up. It's also simply drops down to the lowest position without the lever being pulled. It makes a racheting sound both ways as if the locking pin won't engage.
    Any ideas? I plan to open up the column and look inside at some point - too hot right now though
    95 5spd Pearl White SC, "Millennium TBird" (erst Dr. Jekyll)
    95 Automatic Red SC
    6,804
    Could be the detent spring, pin, rod, mounting screws etc. Might just need to start taking things apart so you can confirm. Begin by removing the 2 piece plastic surround below the steering wheel...see if anything falls out
    How many miles on the body?
    Jan 2015
    240
    She only has 65000 miles, and I'm pretty sure it was like this when I bought her at 60k
    95 Automatic Red SC
    6,804
    Unless it's been abused, it should have at least that many more miles in it before it grenades, I'd think.
    Jan 2015
    240
    There is no reason to suspect any abuse. The car is otherwise quite like new. I've purchased a full 95 steering column and will study how that works before I rip into the white bird column
    95 Automatic Red SC
    6,804
    Let's hope it's a simple fix - keep us posted if you can, thanks and good luck w/it.
    Denver Area
    810
    Good luck man
  1. Removing/altering steering tilt lever
    By jclars in forum Technical Forum
    Last Post: 05-14-2013, 10:51 AM
  2. Tilt Steering Problem
    By BossCougar in forum Technical Forum
    Last Post: 01-02-2007, 01:21 AM
  3. Houston Blower Crew....Leather Steering Wheel Cover Links
    By Steve Ruhl in forum Non Technical Forum
    Last Post: 05-17-2002, 12:47 PM
  4. help, power steering pulley
    By eds94tbirdsc in forum Non Technical Forum
    Last Post: 05-14-2002, 12:10 AM
  5. power steering pulley broken
    Last Post: 05-10-2002, 12:54 AM
