Thread: good spark plugs and wires?
    Sep 2018
    Louisville, KY
    3
    First post. I just bought 1991 SC with 15k miles. I quess I need some help here. there is a miss cylinder 5. I pulled plug and was wet so believe getting fuel. I pulled wire at coil has spark. So maybe back wire. Will investigate. I feel I should start with basics, oil change, spark plugs, wires. What are some good wire and plug options?
    Also looked underneath and have straight pipes from manifolds back to Ford mufflers. There is something loose inside of the mufflers. So I would like to know more on the issue of removing catalytic converters... And if I replace mufflers should I go stock or something else.
    Beginner here wanting to give this low mileage SC some love, TLC.
    Thanks for any help
    Terry
    Nov 2016
    PNW
    299
    Welcome to the forum! Can't go wrong with Motorcraft wires/plugs. Other options of course. Comes down to your budget on exhaust. Search tool is your friend. Any questions just ask.
    Creighton
    Jan 2003
    Woodbridge, VA
    5,239
    Ilike the Autolite professional wires and the autolite double platinums are good too.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
  1. spark plugs and wires
    By automaniak22 in forum Parts for Sale
    Last Post: 08-27-2012, 09:22 AM
  2. Best Spark Plugs And Wires To Use?
    By jjm983 in forum Technical Forum
    Last Post: 08-03-2008, 05:38 AM
  3. What are the best spark plugs and wires to use?
    By blkthndr in forum FAQ Forum
    Last Post: 03-29-2006, 02:49 AM
  4. spark plugs and wires.
    By mn12bird in forum Technical Forum
    Last Post: 11-08-2005, 07:25 PM
  5. Best Spark Plugs and Wires
    By JAFO in forum Technical Forum
    Last Post: 10-19-2002, 12:47 AM
