Results 1 to 3 of 3
Thread: plastic harmonic balancer shroud/cover
    Jul 2018
    Charlotte, NC
    4
    I am in the process of replacing the harmonic balancer. I am almost finished buttoning up when I realized I did not put the plastic shroud back in place. Is this cover necessary for proper operation? I am specifically concerned that the Crank Position Sensor will not function correctly. The crummy Haynes manual I have doesn't even show it as part of the assembly.
    Pacific Rim
    6,722
    Quote Originally Posted by fhrrmc View Post
    AFAIK, the shroud is to protect the sensor from water (temperature shock) and debris. The sensor will work without it, but the risk is early fail over time.
    If this is an early SC, the sensors are hard to find now, even good used, so I'd want to do what I could to keep yours healthy.
    2,237
    Pop over to either HelmINC.COM or to Ebay, and pick up the factory service manual for your year TBird.
    While there, grab the Electrical Vacuum Troubleshooting Manual (EVTM).
  1. Harmonic balancer dust cover
    By Jshep in forum Technical Forum
    Last Post: 07-17-2016, 10:24 AM
  2. WTB Plastic Harmonic Balancer Cover
    By Raymondo in forum Want to Buy
    Last Post: 12-14-2010, 06:06 PM
  3. Harmonic Balancer Shroud.
    By emporio in forum Technical Forum
    Last Post: 10-30-2009, 05:40 AM
  4. Plastic harmonic balancer Cover
    By RedSC93 in forum Parts for Sale
    Last Post: 08-29-2009, 04:49 PM
  5. Plastic cover for harmonic balancer
    By DougD in forum Non Technical Forum
    Last Post: 03-23-2008, 09:41 AM
