Results 1 to 13 of 13
Thread: Help with 91 AODE/4R70W conversion ,Rebuilder Welcome...
    Sep 2006
    New Braunfels,Texas
    556
    This is kinda long,so here goes...I have a 91 SC that I have converted to a AODE/4R70W...The best description of my issue is on initial startup,I back out of my garage,then drive half a block,..trans is in 2nd gear by then and I turn a 90 corner...I accelerate out of the corner and the trans neutralizes...I coast to the curb and come to a stop,put the car neutral or park and then I shift to any other range and no engagement...nothing...the idle may be elevated slightly,at times when it neutralizes, but after a few seconds,I will get engagement...This may happen once or twice,but after it warms up,it absolutely shifts flawlessly ..The trans is a fresh rebuild with less than 100 miles on it...TransGo shift kit and PCS(POWERTRAIN CONTROL SOLUTIONS ) stand alone controller..The trans is supposed to be a 96 or 97 unit...Please,any advice is appreciated
    425
    Good evening
    Below might not be the problem with your transmission but it a start.
    https://www.tccoa.com/articles/transmission/page4.shtml
    Sep 2006
    New Braunfels,Texas
    556
    I can't get the link to open for me...
    Jul 2010
    Peterborough Ontario
    157
    Wrong dipstick &/or tube ?
    If wrong tube or dipstick combo was used during swap, it may indicate fluid
    is full, when it is actually low.
    When you take that first turn, fluid runs away from pick up.
    Once it warms up a bit fluid rise's enough to maintain pressure.
    Just a thought.
    425
    Good morning
    Check fluid level as DOUG H suggested. May need to install 4R70W filter and pan. The pan will have a dimple for extra fluid capacity when making turns. The filter has a pick tube to match.
    Could be as simple as the replacing the filter and pan or the filter clogged.
    Sep 2006
    New Braunfels,Texas
    556
    The pan on this unit is a stock depth cast aluminum pan without the sump...If I recall when i installed this trans,I have 11 qts of fluid in it...The "Add" mark is level with the case or gasket surface...I just can't imagine that it is low on fluid or being starved for fluid because i intentionally overfilled it and have the same issue as described...I did however use the original AOD dipstick and tube on the install...I've changed the EPC solenoid,with no change
    2,237
    Quote Originally Posted by ecyrbh View Post
    It's a Flash page; you may need to use Internet Explorer or FireFox to view it.
    Or enable Flash for that page in Chrome.
    Sep 2006
    New Braunfels,Texas
    556
    Still won't load for me..Three different computers and same thing...I tried Chrome and Flash...Don't have Firefox anymore,I had issues with it...Can you tell me the jest of the article please...
    Pacific Rim
    6,722
    tccoa non-flash articles are here:
    https://www.tccoa.com/articles/tranny/index.html
    ...no idea if they will help w/your issue(s).
    Screenshots of the flash page:
    I noticed the suggestion to use a scotch-brite pad...something I would avoid, and keep away from any engine or transmission, as they contain very small aluminum strands that can easily remain behind after repairs, acting as an abrasive and risking damage to otherwise fragile surfaces/components. Don't think you can simply wipe or clean them away. Better to find other materials more suited for the task.
    Sep 2006
    New Braunfels,Texas
    556
    Quote Originally Posted by sam jones View Post
    Good evening
    OK,now I can see the articles...Which one in particular are you referring to or just all of them in general...
    Sep 2006
    New Braunfels,Texas
    556
    Thanks KMT for the screenshot... I made my reply just as yours came through....
    Sep 2006
    New Braunfels,Texas
    556
    I'm going to take the advice of Doug H and Sam Jones and replace the cast aluminum pan with a 96 steel pan and filter with the deeper sump/tube...If I can source a matching filler tube and dipstick,I'll be doing that too....I currently have the valve body out to inspect and thoroughly clean,just to ease my mind...I hope it's just the transmission breaking in,but during the cleanup,there is a little bit of " pixie " dust coming from the valve body.....Brass or Bronze in color along with what looks like aluminum dust...none of it is magnetic...Any thoughts guys???
    Sep 2006
    New Braunfels,Texas
    556
    Can someone please take photo of a 94 or newer dipstick tube to show how it looks under the hood and give me the length of the dipstick ...According to Ford,94 and newer AODE/4R70W use a different part # than a 91 AOD..Maybe a difference in length or full level marking may help me out...
  1. 91 AOD with 40k on rebuild
    By daverett in forum Parts for Sale
    Last Post: 04-17-2009, 07:52 PM
  2. I need help with some info AOD
    By slow bird in forum Technical Forum
    Last Post: 01-18-2003, 03:17 PM
  3. Help Please: 91 SC with Electical Problems.
    By Tim Groth in forum Technical Forum
    Last Post: 10-21-2002, 11:52 AM
