Jacob_Royer
For sale:
Built 4.2 stroker
Scu rotating assembly which consists of a new crank forged h beam scat rods forged wiesco pistons.
Arp main studs
Arp rod bolts
Melling high volume oil pump
Powerbond ballancer
Arp head studs
MLS gaskets
Attached is the flow sheat on the heads
Stainless valves
Comp lsx beehive valve springs
Comp hardened pushrods
Crane Roller rockers 1.73
Comp. 604/605 226 duration cam
Kooks mid length headers
This engine has approx 5000 miles on it. No blow-by and hot cruising oil pressure of 70psi
It has awesome street manners and brutal low end torque! 13hg of vacuum. Car has gone 11.36 and made 422rwhp @17psi the only reason I am selling this is to fund the purchase of another project. I've been very happy with this motor. With 3.73s and a non locking 2800rpm converter it manages 16/18mpg average.
$4200
I will try to post some pictures up of the engine and flow sheet dyno sheet and time slips later from my pc
You can't build a motor like this for anywhere close to this cheap! I have alot more than this in it. No corners were cut with this build!
Built 4.2 stroker
Arp main studs
Arp rod bolts
Powerbond ballancer
Arp head studs
MLS gaskets
Stainless valves
$4200
