Results 1 to 2 of 2
Thread: Blend Door Actuator 94+ dash
    Blair, Nebr
    3,263
    I posted on the Facebook group, but decided I'd post this over here.
    I just changed out the blend door actuator on the 94. I had searched SCCoA and TCCoA and to my surprise, no one mentioned removing the air bag. I lowered the glove box and removed the air ducts and still wondered how the heck I was going to get the blend door out. I'll post up a semi-how to as well. Perhaps this can help someone down the road when they go to change out theirs. It's not as terrifying as it seems, but still a pain since it's still a tight space behind the dash.
    First, easy stuff - drop the glove box, remove the HVAC ducting (7mm and small Phillips screwdriver) Then remove the four 8mm bolts that hold the air bag in place - obviously, unhook the battery first - and don't forget to unplug the harness for it. I also pulled out the left side vent. You can take out the right side, but I didn't feel it was really necessary.
    The blend door is almost in the middle of the dash, but closer to the passenger side. There are three 8mm bolts that hold it in place. I used a combination of a small ratchet, short extension, 8mm socket (obviously) and 8mm ratcheting wrench. Between those, I had no real issue getting the bolts out. Once removed, it comes out. I pushed it up towards the top of the dash and over dash support pieces and harnesses and out that way. Same way with going back in - keep a hold on it. If you drop it, it can fall far enough to where it's a pain to get it back out.
    **Tip** Remember to line up the gear/shaft with the spot in the ducting (or whatever it is) Otherwise, you'll be pulling everything back out to do that. And if you do forget to do, and run the self diagnostic test, there is no code for that... Ask me how I know this.. Also, don't forget to plug the actuator back in as well.
    I think the hardest part of the whole thing was the orientation of the gear/shaft/whatever to line up correctly. For whatever reason, I could get the old one to line up easy, new one was a pain. Second hardest part, getting one the bolts to line up in the right spot. The top 2 are easy, the bottom right was a pain. So difficult, in fact I managed to drop the one bolt somewhere and have no clue where it went. So mine is only held in with 2. I found it easier to plug it back in once it was bolted in place.
    Once it's in and secure, put the airbag back in - don't forget to plug it back in. Then put the ducting back in with the respective bolts and screw. Then the AC vents, and finally the glove box door.
    No, I didn't pull the dash. Yes it was still a pain, but better than spending time pulling the dash. I think it took me an hour maybe? Hopefully this helps someone down the road.
    Boston, MA
    7,450
    Quote Originally Posted by Melon View Post
    Good tips, I hope I don't ever need to do one.
  1. Grey 94+ Dash and Door Panels
    By JeffTBird93 in forum Want to Buy
    Last Post: 11-04-2014, 09:14 PM
  2. 91 SC Auto-temp blend door actuator????
    By ecyrbh in forum Technical Forum
    Last Post: 07-15-2014, 08:52 AM
  3. 91 SC Heater/Blend door Actuator needed..
    By ecyrbh in forum Want to Buy
    Last Post: 05-24-2014, 08:15 AM
  4. 1995 ford thunderbird ac heater blend door actuator
    By soulcalibur in forum Want to Buy
    Last Post: 06-01-2012, 12:05 PM
  5. 94 SC A/C Blend Door Issue
    By tedallen in forum Technical Forum
    Last Post: 08-04-2007, 09:18 PM
