Results 1 to 2 of 2
Thread: Positive/Negative battery cables for a 90 SC
    SCCoA Member#1257
    3,332
    Looking for a used, but complete, set of battery cables for a 90. Everything from the terminals, to all the branching connectors reaching the starter. I realize by now most battery terminals are shot or have aftermarket ends...that's OK. As long as all the other connectors/ends are OK so that I can plug and play on my 90SC.
    I'm trying to salvage the terminals on my 35th to see if they can maybe be repro'd at a later time, so I want to replace with a good set of used cables with new terminals.
    Let me know what you have!
    Thanks.
    Salem OR
    6,981
    I'd be careful w/older cables...corrosion can hide under the sheath and create resistance you might not want to deal with later.
  1. Looking for a negative battery cable for 94-95
    By kendall221 in forum Want to Buy
    Last Post: 02-07-2007, 11:15 PM
  2. The Search for the Negative Battery Cable Ground
    By C5 Corvette in forum Technical Forum
    Last Post: 01-28-2005, 11:24 AM
  3. FS: DIS for 89-90 SC
    By Turbo351 in forum Super Coupe Club of Ontario
    Last Post: 07-18-2003, 05:53 PM
  4. What is the compression spec for a 90 SC?
    By 90SCinKC in forum Technical Forum
    Last Post: 05-08-2003, 07:21 AM
  5. clear headlights for a 90 SC
    By seannlex in forum Technical Forum
    Last Post: 03-11-2003, 05:40 AM
