Results 1 to 2 of 2
Thread: Is it possible to run the larger 'Sport' pack 11.61" front rotors with PBR Calipers?
    Aug 2002
    Rock Hill, SC
    814
    I need to makeover the front brakes on my 95 SC. They are all factory and all junk, warped rotors (from being undersized from the beginning) and all. I know that there are larger rotors on the 'Sport' packages, on the 96-97 tbirds (maybe just 97), but those are single piston. The brake rotor is larger, 11.61" or so vs. puny 10.8" stock. I want to go with the PBR Mustang Caliper conversion, but that will limit me to the mustang 10.8" (and factory tbird) rotors. Is there any combination of parts will allow the use of the Sport 11.61" rotor and PBR calipers?
    Thanks,
    Jan 2010
    Bossier City, LA
    2,274
    Not with the Mustang GT PBRs, no.
    What you may also do is a) do the hub swap to get to the Mustang pattern, then b) swap in the Cobra brakes.
    Although, TBH, I don't know why you're hung up on the larger rotor; the smaller ones haul Ruby Jean down just fine.
    RwP
  1. Replies: 7
    Last Post: 07-05-2010, 03:48 AM
  2. Replies: 4
    Last Post: 01-05-2005, 11:35 PM
  3. Is it possible to open the sunroof w/o power
    By Dahoopd in forum Non Technical Forum
    Last Post: 09-07-2004, 09:38 AM
  4. Is it possible to replace the spring mechanism in the door?
    Last Post: 04-01-2004, 12:10 AM
  5. When is it safe to run a smaller SC pulley?
    By blkthndr in forum FAQ Forum
    Last Post: 10-28-2002, 07:52 PM
