Results 1 to 4 of 4
Thread: Rust repair under battery tray (pix) what do you suggest?
    SCCoA Member#1257
    3,348
    Iím doing some work on the 35th and I removed the battery. I was a little shocked to find some of the metal under the battery tray was being eaten out. The car has less than 60k miles, so itís most likely due to battery acid from an old or faulty battery. I know the most permanent fix is cutting and re-welding a new metal pieceÖbut that will probably be in the future. Iím curious what you guys suggest as the next best approach without cutting and welding?
    Thanks for any input fellas.
    Salem OR
    7,017
    Ouch, yep, acid...caught it just in time.
    Used POR 15 in the past on older cars with very good results - it's good stuf:
    https://www.amazon.com/POR-15-45004-.../dp/B00H2VVL0S
    A quart should be more than enough for that area. Just be sure to follow the directions for best results.
    Ken
    Feb 2003
    Tinton Falls, NJ
    1,581
    First wash it down with water and baking soda to neutralize any residual acit. Next hit it with a wire wheel on both sides. You will have to remove the wheelhouse liner to access the underside. After that, coat it with POR15 on both sides, then spray paint it with some Rustoleum on both sides. That should stop the rust where it is.
    SCCoA Member#1257
    3,348
    thanks for the suggestions gents.
  1. What do you put in your center console ash tray?
    By Evan_90SC in forum Polls Forum
    Last Post: 04-03-2019, 09:03 AM
  2. What do you think...94 SC with 89-93 rear bumper cover??
    By Mike Manzo in forum Non Technical Forum
    Last Post: 11-20-2011, 01:45 AM
  3. What do you think of the 2001 Tbird?
    By TbirdSCFan in forum Polls Forum
    Last Post: 04-22-2005, 04:12 AM
  4. Heads, what do you recommend?
    By BlueThunder90 in forum Super Coupe Club of Ontario
    Last Post: 05-07-2002, 11:48 AM
  5. what do you think we should do about terrerist?
    By desertzany in forum Polls Forum
    Last Post: 04-09-2002, 02:47 PM
