Results 1 to 6 of 6
Thread: Compatibility 1990 SC engine and 1995 SC engine.
    Apr 2018
    North Bay, Ontario
    35
    Hey all,
    Have my 1990 SC, and looking at rebuilding and installing a 1995 SC engine in it. I know things changed over the years, question is, would it be a direct swap over, or is there re-pinning, module swapping, etc to do. Both cars are manual cars.
    Any insight is appreciated!
    James
    Salem OR
    6,938
    James:
    Do you want to take the path of least resistance and just bolt things back in, or do you want to try to make a '95 out of your '90?
    I think if you just stick to the built block w/heads you won't have any issues.
    If you want to run the 95's larger injectors to take advantage of the better intake/supercharger things get tricky, but doable. If you want the improved late model exhaust manifolds you'll need to modify the '90's system, or install the 95's system and fuel tank.
    Some FYI internal diffs noted in this thread if you're curious: http://www.sccoa.com/forums/showthre...+block+changes - all good news in your example.
    Ken
    Roanoke, Virginia
    3,309
    The long blocks are interchangeable. Use your 90 front cover, balancer and the 90 electronics (DIS module) and you'll be fine.
    -Tim
    Current Collection
    1995 Thunderbird SC - Auto
    1994 Thunderbird SC - 5spd
    Aug 2005
    Paoli Indiana
    4,727
    -Tim
    I just went through this 95 to 90 swap and I am pretty sure the late model cover will work with the early ballancer and crank sensor
    93 SC Red Aod 4.2/2.3lwhipple 422rwhp 11.360
    2013 Shootout Bracket ET First Place
    2015 Shootout Car Show Honerable Mention
    2016 Shootout Mod-1 First Place
    2018 Shootout Pro Street Runner Up
    Coming soon new motor 2300 TVS etc..
    90 35th aod stock, 90 5 speed Bolton Build in progress
    Jul 2010
    Peterborough Ontario
    170
    90 to 95 compatibility
    Very hard to find replacement early model crank sensors now?
    Might be good time to update?
    Nov 2010
    Northern New Jersey
    2
    Amazon has the crank sensors for around $70 now. I think they are coming from carid.
  1. 89 sc front and 94 sc rear bumper 4sale
    By 92tbird04 in forum Parts for Sale
    Last Post: 10-26-2009, 04:32 PM
  2. 92 sc auto and 89 sc five speed
    By scfix92 in forum Cars for Sale
    Last Post: 12-07-2007, 01:41 AM
  3. Several SC seats and many SC parts available.
    By Randall Burnett in forum Parts for Sale
    Last Post: 10-21-2007, 06:39 AM
  4. Bare SC block and White SC doors for Pick up only
    Last Post: 02-12-2006, 06:32 PM
  5. 1990 sc computer and engine wiring harness
    By racebronco2 in forum Parts for Sale
    Last Post: 01-03-2006, 12:54 AM
