Thread: Ditched the EGR components on my 89 SC – need help on vacuum lines
    Oct 2018
    Colorado Springs, CO
    14
    OK, as the title indicates I removed the EGR valve from my 89 SC. Yes, I sliced and diced just about every search phrase variant here and on the Web looking for REAL answers. So, a quest for real answers is the focus here.
    But, gawd, what a ~~~~ *that* was removing the EGR! I swore I would not be putting the eff’ing thing back on after I tore the top end apart replacing the fuel pressure regulator which started this entire challenge
    In removing the EGR stuff I ended up cutting off the bottom end of the tube using several sacrificial small cutoff wheels in my Dremel tool.
    An EGR removal kit was ordered from SpinningWheels-SC but only the blocking plate intended for the air intake plenum assembly fit. The brass cap intended to cap off the fitting on the exhaust collector was too small. [See unnumbered picture below.] I ended up using somebody else’s brilliant idea of Penny at the bottom of the original tube capture nut. So much for the helpful EGR removal kit.
    • The leftover EGR transducer – I’m assuming that whatever the hose was plugged into is gone, thanks to my enthusiastic effort to remove what it was plugged into. So I’m thinking it will be no big deal to simply block the tube – see photo #1 – and leave the connector in place (and protected) with the transducer still plugged in. I’ll find a new happy home for this remnant and tie wrap it somewhere out of the way. Does that make sense?
    • Mystery vacuum(?) hose fitting – see photo #2/drawing. The back end of the supercharger/air intake plenum assembly has a 5/16"(?) hose fitting that dearly needs something connected to it. Any clue on what that connection might be? Yes, I thought I tagged and photographed everything during the tear down but this one got away.
    • Passenger side PVC valve hook up – see photo #3. I dug up the business end of this assembly from over the valve cover just for photo purposes. The end swings down and it’s supposed to get connected to some sort of vacuum source. The far end of this deal is a hard plastic vacuum line that disappears down the rabbit hole to the interior. Presumably to so some sort of accumulator associated with interior heater/AC controls? So, what should this tubing end be hooked up to? Maybe extended to connect to the fitting shown in photo #2?
    Any and all replies and clues are appreciated. Thanks in advance!!!
    MDW
    Salem OR
    6,935
    These images from previous threads might help?
    The red box in the one image illustrates a blocked off/non-EGR configuration. The tube end you circled in your image #2, is on the left in that box and goes to the PCV.
    Name:  engine pic 2.JPG
    Oct 2018
    14
    Two words: Wow and Thanks [you very much]. The fog is lifted!!!
    MDW
  1. Gauging interest on my 89 SC
    By fastfordfan1 in forum Cars for Sale
    Last Post: 11-28-2006, 05:06 PM
  2. will this thottle body work on my 89 sc
    By Blue89SC in forum Non Technical Forum
    Last Post: 08-08-2004, 11:51 AM
  3. Where is the fuel pump relay on my 89 SC?
    Last Post: 04-18-2003, 11:33 AM
  4. noisey sunroof on my '89 SC
    By radiorick in forum Non Technical Forum
    Last Post: 10-26-2002, 10:55 AM
  5. Changing A/C compressor on my 89 SC
    Last Post: 07-25-2002, 05:50 PM
