Matt_aka_Dale
At warmed up idle, fuel pressure is showing a steady 31psi. When key on, it shows max of roughly 28-29psi, but slowly drops to 11psi. The only leak I know about is the oring at the top of the sending unit. Fuel regulator is not leaking either. Do the readings I've found seem correct/incorrect?
