Thread: Fox 302 install
    Nov 2017
    21
    Fox 302 install
    I know the ideal scenario for swapping a SC to a 302 is to use the 302 setup from a 91-93 bird. While I was completely planning on doing this I ran across a deal I could not pass up on a 302 out of an 88 mustang GT. In the excitement of picking up the motor and getting it set on the engine stand to go over is when I truly understood how much harder I had made this swap on myself. The plan for the 302 swap is to go with a carburetor set up. I'm currently deciding whether I run the stock FI pump with a good fuel pressure regulator or possibly run a mechanical pump with timing cover provisioned for mechanical pump. Fuel delivery can be handled a few different ways but where I believe I am stuck is with the whole front engine accessory setup. I have everything from the fox mustang with the exception of the power steering pump. I still have all of the SC brackets and accessories too. I do not plan to utilize any smog or air conditioning once the swap is complete. Has anyone successfully adapted the SC accessories to a
    302 without the original mn12 302 bracketry? If anyone has experiences or ideas they would like to share I would greatly appreciate it. I'd like to get a perspective other than my own at this point. Thank you
    Jan 2010
    Bossier City, LA
    2,278
    I can find billet accessory drive kits for a 1994/1995 Mustang GT with the 5.0HO; which said motor is almost identical to a 1993 TBird/Couger 5.0HO. And has as its major variance the extension of the alternator bracket for the larger alternator ...
    Win/win IMO!
    RwP
    Jan 2003
    Woodbridge, VA
    5,204
    I would just stick with the electric in tank pump and good low pressure regulator.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
  1. Air Dam Install, With Pics
    By Bob Pringle in forum Technical Forum
    Last Post: 07-14-2002, 09:23 PM
  2. What needs to be replaced when installing new springs?
    By Seshead in forum Super Coupe Club of Ontario
    Last Post: 05-22-2002, 04:14 PM
  3. BEST PLACE TO INSTALL 'SC' SPRINGS?
    Last Post: 05-22-2002, 09:37 AM
  4. K-member install, anyone done that?
    By mRbojangles in forum Non Technical Forum
    Last Post: 05-02-2002, 09:37 PM
  5. Installation of MN12Performance Front Susp. Kit
    By JTBIRDSC in forum Polls Forum
    Last Post: 10-15-2000, 09:40 PM
