Results 16 to 17 of 17
Thread: PS rack pressure and return line teflon O-rings
    Mar 2017
    Sweden
    68
    I am now convinced the parts numbers for the rack to elbow tube connections seals are the following:
    Pressure line to rack teflon seal 388897-S
    Pressure line to rack rubber o-ring 388748-S
    Return line to rack teflon seal 388898-S
    Return line to rack rubber o-ring 388749-S
    7,012
    Quote Originally Posted by onkelmicke View Post
    I am now convinced the parts numbers for the rack to elbow tube connections seals are...
    Looks like it, yes.
    • Hi Pressure Hose to Rack (rubber, small)
    - Ford #388748-S,
    Danco 96722 #5 3/8" OD x 1/4" x ID x 1/16" diameter
    • Hi Pressure Hose to Pump (rubber, large)
    • Low Pressure Hose to Rack (rubber, large)
    - Ford #388749-S,
    Danco 96723 #6, 7/16" OD, 5/16" ID x 1/16” diameter
    PM sent.
  1. 90 Fuel Tank feed and return line
    By Les Borda in forum Technical Forum
    Last Post: 08-13-2014, 10:31 PM
  2. Is the Pressure connection on the PS Rack 16mm?
    By DBs955spd in forum Technical Forum
    Last Post: 11-18-2010, 08:26 PM
  3. High pressure p/s line and aod clip
    By 91BlackBird in forum Want to Buy
    Last Post: 06-04-2008, 01:56 PM
  4. Replies: 0
    Last Post: 10-19-2002, 01:17 PM
  5. Time for Carlisle Departure and Return?
    By Wayne Ing in forum Super Coupe Club of Ontario
    Last Post: 05-11-2002, 01:54 AM
