plstktnkr2
I have an aftermarket tach and I need the wire lead colors and location of said wire. Any reasonable help appreciated.
Rick
Rick
Rick
Won't that depend on the aftermarket tach?
Unless you're looking for where to connect it ... and checking a 1994 EVTM (what I have right handy), it says the tach comes in the instrument cluster on a White/Pink wire.
It's on pin 4, an Orange/White wire, on the PCM - and on pin 2 of the ICM.
For a 100% accurate answer, please check your EVTM (section 21 most likely) or at least give year so someone can check their EVTM in case the colors changed year to year.
RwP
