Results 1 to 10 of 10
Thread: 1994 Thunderbird Super coupe 5spd
    May 2015
    Kelowna BC
    40
    Here is a 94 Super coupe 5spd this was an Automatic car converted to 5 spd
    The car has 170K and lots of updates
    Engine: Kooks headers, 42lb injectors, ported supercharger,
    Aurora wires and platinum plugs
    70MM Throttle body, 70mm MAF, ECU tuned by SCU chip.
    2.5” true dual exhaust with Magnaflow mufflers
    Mp raised hat, double inner cooler with fan, Fuel pressure regulator, 255LPH Walbro fuel pump .
    New center force clutch at 160K with trans install also a B&M ripper shifter.
    Front Suspension:
    Converted to 5X4.5 bolt pattern same as the mustang
    Tokico adjustable Struts VOGTLAND sport spring new lower and upper control arms
    All new bushings and aluminum rack bushings
    Chassis Bracing Front brakes are 13” mustang Cobra
    Rear Suspension:
    VOGTLAND sport spring Tokico adjustable struts Mustang 12” cobra brakes
    Ford racing rear diff cover 3:27 gears with a carbon fiber track loc.
    Rear pinion bracing and poly bushings
    1X9 Cobra R wheels with 255 40 17 Nitto tires.
    All LED exterior lights
    Blue tooth deck with Sub box
    $4000 US $5500 CAD
    The car is in Kelowna BC and I can work with an out of province buyer
    May 2015
    Kelowna BC
    40
    Price drop to $4900 CAD $3500 USD
    May 2015
    Kelowna BC
    40
    up to the top
    Aug 2007
    225
    Is that a black interior?
    Michael
    May 2015
    Kelowna BC
    40
    No it is blue.
    SCCoA Member#1257
    3,386
    Is that performance (bright) white or pearl white?
    May 2015
    Kelowna BC
    40
    I have added the door tag pic to show the paint code
    Nov 2012
    Canton, GA
    358
    Quote Originally Posted by Merc460 View Post
    The picture of your door tag is so small I can't read it. It also looks like the paint code would have been cut off anyways.
    May 2015
    Kelowna BC
    40
    Lets try this
    Nov 2012
    Canton, GA
    358
    Thank you.
    WT is “Performance White” for most Fords or “Vibrant White” for the 1994-1997 Thunderbird.
  1. 1994 Thunderbird Super Coupe (FOR SALE)
    By RyanA in forum Cars for Sale
    Last Post: 06-19-2015, 11:36 PM
  2. Ford Thunderbird Super Coupe 1994 $3300
    Last Post: 09-22-2010, 09:08 PM
  3. Replies: 7
    Last Post: 04-12-2010, 09:30 PM
  4. 1991 Thunderbird Super Coupe 5spd - $600
    By sumzxr7 in forum Super Coupe Club of Ontario
    Last Post: 10-06-2006, 01:47 PM
  5. Replies: 3
    Last Post: 12-27-2004, 01:43 PM
