Results 1 to 10 of 10
Thread: Black XR7
    Jun 2019
    5
    Black XR7
    Having problem with idle. starts good.
    May 2004
    Va. Beach,Va.
    7,116
    Quote Originally Posted by Black XR7 View Post
    Could be bad IAC (idle air control valve) on side of throttle body or vacuum leak, the 2 most common problems for this issue.
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    '90 SC AUTO - Bone Stock
    Salem OR
    7,197
    Before you fire the parts cannon at it...check for codes.
    No codes, hit the throttle body with spray cleaner to be sure it's not junked up inside/around the throttle plate. Still no joy, as nickelman60 notes, start looking for vacuum leaks.
    Does it make a honking noise at idle? How many miles on the plugs/wires? Can you better describe the problem...does it hunt, stall, race, need nursing...? Any mods? Been sitting? Is the problem the same with both cold and hot starts?
    Jun 2019
    5
    BlackXR7
    I received my xr7 from my son when he joined the army sixteen years ago . I'v rebuilt the motor it's board 40 over. the car will start but will not idle, iv'e had to move the distributor 1 gear tooth clock wise for it to start. I have taken it around the b lock it seems to run good , however I need it to Idle . Do I need to turn the electronic distributor in order for it to idle. My son is still in the army I would like to get this done before he retires.
    Salem OR
    7,197
    Sorry, I assumed when you said XR7 you meant the Mercury Cougar version of the Ford Thunderbird Super Coupe, supercharged V-6. Those are the models I had in mind when discussing troubleshooting, but they do not have a distributor.
    What year car are you working on, with which engine?
    Jun 2019
    5
    BlackXR7
    It is and has a DIS type ign.
    Jun 2019
    5
    Black XR7
    also I have to nurse throttle to keep running. thanks mike
    Salem OR
    7,197
    Mike:
    has a DIS type ign
    Got it, thanks. I take it you meant the cam sensor stalk when you said 'electronic distributor'.
    See this thread on how to set it up:
    http://www.sccoa.com/forums/showthre...m+sensor+drive
    There is also an alignment/synchronizer tool you can buy that helps:
    What happens to the idle if you disconnect the connector at the cam sensor and start the car? It might take more than one try, but just get it running, then observe the idle. Not sure there is a relationship between the two in your case, tho. I suspect there are vacuum leaks after the rebuild that you need to track down and fix.
    After the rebuild, what did you use to reseal the intercooler tubes when you put it back together?
    Did you check the inside of the throttle body for any black deposits? 40 over is going to need all the air it can get
    Ken
    Jun 2019
    5
    Black XR7
    I will check these things out and get back with you in a couple days i'm taking my grand kids camping . Thanks
    21,081
    Set the idle with idle air adjustment screw (top right side of TB). If it wont idle it's probably a vacuum leak on one of the IC tube connections. Spray with carb cleaner to locate leak. The only way to advance/retard ignition timing is with a tuner/programmable chip like Binary Editor and Quarter Horse.
  1. Black XR7 Front Bumper Cover
    By Thomas A in forum Want to Buy
    Last Post: 07-27-2007, 01:35 PM
  2. Black XR7 5spd.
    By XR7Kurt in forum Want to Buy
    Last Post: 05-07-2007, 07:12 PM
  3. 1993 Black XR7 - Parting Out
    By gmsuks in forum Parts for Sale
    Last Post: 04-13-2006, 11:19 AM
  4. Is it Bling if its Black? XR7 pics inside
    By getblown in forum Non Technical Forum
    Last Post: 10-14-2004, 09:55 PM
  5. 89-90 black xr7 in vincennes indiana?
    By pdennis93 in forum Non Technical Forum
    Last Post: 09-15-2002, 12:10 PM
