Results 1 to 15 of 18
Thread: LED lights
    Feb 2003
    Murrysville, PA
    1,276
    LED lights
    Just got done outfitting the entire car with LED ďbulbsĒ. This was primarily to reduce the electrical load on my under driven alternator, rather than the cool factor. I opted not to do the corner lights as I found the resistor that was required got extremely hot, very quickly. I should note that I got what appeared to be the proper LED lights where the LED is oriented where the halogen filament would typically be. As opposed to a bulb which has tiny LEDs covering the entire surface area.
    Does anyone else have experience running LED lights throughout the car with under drive pullies?
    I did find the driver fog light harness was reversed polarity, and had to correct that. Is it even worth changing the corner lights, considering the soldering and resistors which need to be added?
    -Tesla Model 3 Performance-
    -89 White 5-speed, 450HP 430TQ-
    My garage
    Jan 2010
    Bossier City, LA
    2,290
    Quote Originally Posted by Tony8470 View Post
    What resistors?
    You don't need resistors.
    But first, what year is your SC?
    1st Gens will take some custom wiring to support a LED flasher, but the good old Novita EP27 will do the job if you wire a new socket in for it.
    On the 2nd Gens, just buy a EP34 and swap that.
    Can we get a picture of the light pattern against a wall from, say, 10 to 20 feet away?
    RwP
    May 2009
    Brownsburg, IN
    153
    LED flasher
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I got some switchback LED corner lights and installed this flasher. It worked great and allows me to adjust the flashing speed from very slow to very fast, wherever I want it.
    Jan 2010
    Bossier City, LA
    2,290
    Quote Originally Posted by Norm-L View Post
    And what year is yours again? 94, 95?
    RwP
    Feb 2003
    Murrysville, PA
    1,276
    Itís an 89.
    The resistor functions to add a load onto the flashers. It prevents rapid flashing. It looks like I can just replace the relay though? That would be nice.
    The car isnít movable at this time. But I do feel the headlight beams are going where they should be.
    My garage
    Jan 2003
    Woodbridge, VA
    5,240
    I got some LED headlight bulbs for my 94 from a thread over on TCCoA. Much better brightness. I will try to get a pic up.
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Jan 2010
    Bossier City, LA
    2,290
    Itís an 89.
    The only problem is there's not a plug in LED compatible flasher; there's a FUNCTIONAL identical unit to our flashers, though, so I rewired to use the EP27 flasher module (it plugs into a 5 pin Bosch relay socket, so they're fairly cheap; if you're paranoid, you can even take the Bosch socket, put male FastOn(tm) type quick connects on the wire, and just plug that into the factory socket).
    I'll have to dig up the wiring, though; it wasn't quite a plug 1 into 1, 2 into 2 etc. job. (It's a 1 for 1, but not in the exact same order.)
    RwP
    Feb 2003
    Murrysville, PA
    1,276
    So it sounds like the EP27 module is made for LED flashers? If thatís the case. Do you have any pictures of your setup?
    My garage
    Jan 2010
    Bossier City, LA
    2,290
    I don't know if I can get a pic now; let me see if I can tomorrow.
    RwP
    May 2009
    Brownsburg, IN
    153
    Mine is a 95
    RwP
    May 2012
    Denver Area
    930
    Any chance you can share part numbers for LED's you've installed? The flasher info is great - interested in the bulb choices.
    Feb 2003
    Murrysville, PA
    1,276
    9005 High Beam - CougarMotor LED Headlight Bulbs All-in-One Conversion Kit - 9005-7,200 Lm 6000K Cool White CREE - 2 Year Warranty https://www.amazon.com/dp/B01H6NZ6F2..._ylNiDbMX412E7
    9006 Low Beam - CougarMotor LED Headlight Bulbs All-in-One Conversion Kit - 9006-7,200Lm 6000K Cool White CREE - 2 Year Warranty https://www.amazon.com/dp/B01H6NZ7BA..._CsNiDbESH0XPY
    Those came in the same packaging. I donít think there was a difference.
    880 Fog - BEAMTECH 880 LED Headlight Bulb, 50W 6500K 8000Lumens Extremely Brigh 885 893 899 CSP Chips Conversion Kit https://www.amazon.com/dp/B06XHF7YVR..._xtNiDbY9Z0VK8
    The 880 fog light heat sinks had to be cut in half. They wouldnít go in all the way otherwise. I donít think any LED light will work there without some sort of modification.
    3157 Corner - Yorkim Super Bright 3157 LED Light Bulbs White Pack of 10, 3157 LED Brake Lights, 3157 LED Backup Reverse Lights, 3156 LED Reverse Tail Lights, Turn Signal Led - 3056 3156 3057 3157 4157 LED Bulbs https://www.amazon.com/dp/B01A4Z3FOS..._3sNiDb153WEXZ
    3157 Corner (amber) - Yorkim Super Bright 3157 Amber LED Bulb, 3157 LED Brake Lights, 3157 LED Backup Reverse Lights, 3156 LED Tail Lights, Turn Signal Bulb with Projector - 3056 3156 3057 3157 4157 LED Bulbs, Pack of 2 https://www.amazon.com/dp/B07KZVM2KN..._VuNiDb17TXYGH
    3156 Reverse - iBrightstar Newest 9-30V Super Bright Low Power 3156 3157 3057 4157 LED Bulbs with Projector Replacement for Back Up Reverse Lights and Tail Brake Parking Lights, Xenon White https://www.amazon.com/dp/B01MDUEBX1..._XtNiDbDWRNSJP
    194 Interior - Yorkim 194 LED Bulbs Xenon White 6000k Super Bright Newest 5th Generation, T10 LED Bulbs, 168 LED Bulb, LED Bulbs for Car Interior Dome Map Door Courtesy License Plate Lights W5W 2825, Pack of 10 https://www.amazon.com/dp/B00JRE38EA..._-BNiDb081ERQ0
    These 194 interior lights I had installed a few years ago. A few are flickering. I would highly recommend using dielectric grease on these (on all for that matter) to reduce oxidation at the contacts. I believe thatís what the issue is. I even went so far to replace the dash lights with these. All still work except the high beam, which Iím just lazy to get back to again.
    1156 Interior - HOTSYSTEM 10pcs 13-SMD 1156 Ba15s 12V Backup Signal Blinker Tail Light LED bulbs White https://www.amazon.com/dp/B00LBVV7AO..._eFNiDbH98YMWV
    I think thereís only two of these in the car. These illuminate next to rear seat heads.
    A few notes. I went through the routine of sourcing appropriate bulbs about 2-3 years ago, and many of those manufacturers no longer exist. As well, this is all obviously Chinese Amazon stuff, so your mileage may vary. Oh, and I just realized I still have to replace the turn illuminator lights...
    My garage
    Feb 2003
    Murrysville, PA
    1,276
    Yorkim 50W 6ohm Load Resistors, Fix LED Bulb Fast Hyper Flash, Turn Signal led Blink or Festoon Error Message, Warning Cancellor, Pack of 4 https://www.amazon.com/dp/B07KS6KMYG..._VSNiDbG7VF992
    These are the janky resistors I thought I would have to put in. And did put one in, before taking it out. Hoping the relay is a better solution.
    My garage
    Salem OR
    7,307
    part numbers for LED's - interested in the bulb choices.
    I haven't made the leap to LED head/tail, cluster yet, but I've tried to do the rest. I did the backup lights first, back in 2011, and they were the most expensive but a big improvement. There weren't a lot of choices then, but today it seems like most everything has an LED equivalent. I tried using the Sylvania bulb listings for #s but found that some in my Anny were different. The bright white for the map (tricky to install) and courtesy lights is a big help.
    Note that you can find different lights with same part number where there come with more or less SMDs. There more there are, the brighter the light, but also the longer the bulb. I used the ones with the most SMDs I could find for the courtesy lights in the upper rear and under dash; medium length for the courtesy lights in the doors; shortest I could find for the single light inside the center console. I tried a longer one, which fit, but it went right up against the lens and created a bright spot that looked out of place. YMMV so be flexible.
    They all illuminate quicker and generate much less heat, a bonus with our aging wiring. This list is from 2014, reflects my 1990 SC Anny, and should still apply.
    • Rear license plate - 2 - 194?
    • Center high brake - 2 - 194 or 921?
    • Trunk interior - 1 - 194
    • Cornering - 2 - 3157a (?)
    • Under hood - 1 - 194
    • Glove box - 1 - 194
    • Map lights in mirror - 2 - 194
    • Center console - 1 — 1895 (used SMD 4, shorty)
    • Upper rear interior courtesy - 2 — T89
    • Under dash courtesy - 2 — T89
    • Fog lights - 2 — 880
    • Backup lights - 3156 - 2
    • Door courtesy - 2 — 194
    Feb 2003
    Murrysville, PA
    1,276
    Has anyone tried replacing the bulbs in the HVAC controls? Iíve tried twice now with no success.
    My garage
  1. 94-95 tail light - LED light set
    By Raptor in forum Parts for Sale
    Last Post: 12-20-2006, 10:44 PM
  2. Need burned out RED LED light panels...
    By Mercury267 in forum Want to Buy
    Last Post: 03-17-2006, 12:06 PM
  3. New style trunk lid, led lights & corner lights
    By minbe in forum Super Coupe Club of Southern California
    Last Post: 10-29-2005, 04:16 PM
  4. New style trunk lid, led lights & corner lights
    By minbe in forum Super Coupe Club of Northern California
    Last Post: 10-29-2005, 04:14 PM
  5. rear led light on trunk question?
    By ddw350 in forum Non Technical Forum
    Last Post: 07-10-2002, 08:20 PM
