Page 1 of 5 12345 LastLast
Results 1 to 15 of 74
Thread: Official: Stuff you have left to do before the midwest bash thread.
    Aug 2005
    Paoli Indiana
    4,854
    Let's see what you guys have going on!
    I still have to:
    Replace brake booster (again)
    Install wideband
    Install qh
    Setup new tuning laptop
    Install wiper motor/cowl
    Install hood
    Replace multifunction switch
    Plates
    Insurance
    Swap wheels
    Locate some slicks to borrow(my drag radials would be bad with a five speed)
    Swap diff for 3.27 I have
    Swap speedo gear
    Tune the car(should be easy nothing crazy just bolt ons)
    Swap seats(car has junky sho seats I have a mint set of grey cloth)
    Install manual seat tracks during swap
    Fix the auto seat belts (i have good ones) or Manual belt swap.
    Clean the hell out of it detail wash/wax
    Locate some spare halfshafts
    Find/fix ac leak only holds vacuum for 2 minutes had no dryer when i got it so replaced it and all the seals under the hood plus the line that has the orfice tube.
    93 SC Red Aod 4.2/2.3lwhipple 422rwhp 11.360
    2013 Shootout Bracket ET First Place
    2015 Shootout Car Show Honerable Mention
    2016 Shootout Mod-1 First Place
    2018 Shootout Pro Street Runner Up
    Coming soon new motor 2300 TVS etc..
    90 35th aod stock, 90 5 speed Bolton Build in progress
    Milwaukee, Wisconsin
    3,496
    put this thing in
Size:  34.8 KBName:  2.jpg
Size:  34.5 KBName:  3.jpg
Size:  2.2 KBName:  4.jpg
    santa came early so now I got to get this in...Rich
    Too many cars,too little time to drive them. Anything less than 500 cubes is a small block. If you slow down in life you will get run over..
    3,496
    got some slicks here
    Jacob, my son has a set for sale if you need some. Look up to see if they would work for you... His handle is Nasty V6.... Rich
    Aug 2005
    Paoli Indiana
    4,854
    Quote Originally Posted by pro street rich View Post
    I believe I have located a set I can use. I switched to 275/60/15"et po radials on my red car they are sweet with an auto! I'd say instant broken crap with a five speed
    May 2003
    Omaha, Nebraska
    6,248
    Finish rewiring the entire ECU, transbrake, two step, overdrive and misc wiring. What fun
    Ken
    93 SC Whipple powered 11.648 @ 119.6
    Twin Turbo, air intercooled..yet to see
    21,099
    Wash my car....
    3,496
    order a new flex plate
    well I found out that this new trans needs another flex plate so now I have to order one and wait for it to come... oh well then it is down to clean wash and put the tires on it....Rich
    Aug 2005
    Paoli Indiana
    4,854
    Wash my car....
    I miss those days! I enjoyed that mode of sc ownership for a couple years then decided to tear my crap down and start building another car in the middle of it while I was waiting on parts
    21,099
    Quote Originally Posted by Jacob_Royer View Post
    Jacob,
    Did all my mods for the year in the Spring. I'm just planning to put a mix of race gas and pump gas in it, and run on the race tune all weekend.
    Aug 2005
    Paoli Indiana
    4,854
    Got alot done yesterday! Mike Inch, Dan Thornsberry and Matt Haub all stopped by to help out!
    Brake booster replaced
    Hood latch cable and handle installed
    Seat swap mostly done (missing a few pieces I have next few days)
    Mtxl wideband and boost guage installed and wideband js wired to the egr so no need for the serial to parallel adapter bs!
    Also discovered the wiper motor is jacked up so ordered a new one.
    Still need to :
    Install wiper motor and hood
    Install qh
    Swap diff
    Tune
    Fix ac
    Aug 2005
    Paoli Indiana
    4,854
    I ordered an el cheapo digital temp gauge to fill the empty hole in my pod. I couldn't justify spending the $ on a innovate guage on a free car. All the factory crap works but I didnt want an open hole. I also think better temp monitoring is important. I'm going to go ahead and wire it before I put the pod back in.
    3,496
    got my butt kicked
    Well I got my butt kicked this weekend. I have been working on this car to get it ready . I wanted to put in a different trans so I ordered one and pulled out the old one. Then the fun started, The new trans has a "SFI" bell housing so when I put it up the flywheel was too big to fit into the bell housing. so out it came again and we ordered a new flywheel to fit. Got it and again put it up only to find out that the bolt pattern was wrong on the convertor, so we ordered a new one of that. Got the new convertor and put it all back together only to see there was a extra piece on the convertor that was hitting the flywheel. So now it is time to wait for yet another convertor that should fit. I sure hope so and YES I should have checked everything better before I got into this mess.. When this is done I still have some interior work as well some wires to run. Maybe it will be ready for the bash otherwise I guess I will have to bring something else....rich
    Aug 2005
    Paoli Indiana
    4,854
    What time are we planning on racing Sunday?
    3,496
    track opens at 8:00
    The track opens at 8:00 and we can start then. Everyone can get in some test runs and then we will work thru the racing from there. We can play as long as we want and everyone should get in as many runs as they want....Rich
    Aug 2005
    Paoli Indiana
    4,854
    Temp guage installed:
    New wiper motor installed and hood back on
  1. Shootout time! what do you have left to do?
    By davec73 in forum Non Technical Forum
    Last Post: 10-02-2017, 07:44 AM
  2. So what do you guys have left to do for the shootout???
    By Jacob_Royer in forum Non Technical Forum
    Last Post: 09-29-2016, 07:59 PM
  3. What do you have left to do for 2014 Shootout ?
    Last Post: 10-07-2014, 03:12 PM
  4. Shootout!!! What do you have left to do?!
    By DrFishbone in forum Non Technical Forum
    Last Post: 09-19-2011, 12:43 PM
  5. This is hilarious if you have time to read it all.
    Last Post: 04-30-2002, 08:39 AM
