Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 74
Thread: Official: Stuff you have left to do before the midwest bash thread.
  1. #31
    Milwaukee, Wisconsin
    3,510
    moving right along here
    Well after making the air VERY BLUE in the shop I did get this new transmission in the car. The big issue was they forgot to drill a hole in the block plate, found that before install. But then when everything was bolted in the starter bolt holes are off, again on the block plate. So now you got to take it apart and redrill them.. Boy it is so nice to buy quality parts from a name brand company like quick time/holley only to find out that they are just pounding out JUNK.
    Well the bottom line is I got everything redrilled and put together. so now it is on to the rest of the car.....time is going on the rest of this car.. Rich
    Too many cars,too little time to drive them. Anything less than 500 cubes is a small block. If you slow down in life you will get run over..
  2. #32
    English, IN
    4,513
    It's tough finding the time to work on the car, but made some progress....here's whats left:
    - Install all engine accessories
    - Install long tube headers / rework exhaust
    - reroute heater hoses to passenger side
    - install SCT Slot MAF
    - Re-tune
    - Drive the car
    - Check hot valve lash / adjust
    - Clean it up some and hope it holds together
    Matt Haub
    Shootouts: '09 SS 1st | '10 Mod1 2nd | '11 Bracket 3rd | '12 Bracket 1st | 2013 | '14 Bracket 3rd | 2015 | '16 Bracket 1st & Mod2 2nd | '17 Spectator | '18 Freeze-Plug Champ
    Black '89 5spd - 281K miles, MPx, Alky-Inj 387rwhp, 438rwtq (new motor) Best 1/4mi:12.521, MPH:107.23mph (old motor)
  3. #33
    3,510
    well went for a ride tonight.
    Well I got my beast out of the shop today and took it for a ride. Everything with the exception of a couple of gauges worked fine. We drove to a cruise night eat some food and then came back home. Just before we got home I stopped on a quiet road and let it rip. I didn't use the trans brake but I tell you what, this thing took off with the rubber sticking to the road. tomorrow I will look at a couple of things but it does look to be ready to play in a few weeks.....Rich
  4. #34
    Aug 2005
    Paoli Indiana
    4,855
    Last night I did the gear swap to 3.27s and also polly diff bushings and a new fuel filter.
    93 SC Red Aod 4.2/2.3lwhipple 422rwhp 11.360
    2013 Shootout Bracket ET First Place
    2015 Shootout Car Show Honerable Mention
    2016 Shootout Mod-1 First Place
    2018 Shootout Pro Street Runner Up
    Coming soon new motor 2300 TVS etc..
    90 35th aod stock, 90 5 speed Bolton Build in progress
  5. #35
    May 2009
    Brownsburg, IN
    158
    Surprisingly caught up
    I was 3 hours late for my appointed move-in time for the World of Wheels. I was cleaning until 4:30am the morning of the big All-Ford Show. I got 2 hours sleep before Artomobilia here in Indy. I have a really bad habit of dragging things out to the last minute. For once, I'm on schedule after securing transportation to the Bash yesterday. That was my last task that I needed to do.
    I guess I could say there's one more thing I should need to do. Considering how susceptible I am to falling asleep on long drives, it would probably be good to find someone available to ride shotgun to keep me in check. I'll call that the last thing I need to do before the bash.
    I'm really looking forward to catching up with more MN12 owners and checking out your cars. See ya there.
  6. #36
    Aug 2005
    Paoli Indiana
    4,855
    I've got the gears swapped to 3.27s and now have a working track lock, also found a broken but still working half shaft I swapped when I did it. And installed polly diff bushings. But I'm suspecting this 500 mile spec clutch is slipping and no matter how much I add to the car over 3.5v vmaf it runs lean so I am going to put a bigger fuel pump in and hope it resolves it.
  7. #37
    English, IN
    4,513
    Quote Originally Posted by Norm-L View Post
    Maybe join the caravan? That might help! Sounds like Mike Inch, Jacob Royer, Dan Thornsberry and I may all be caravan-ing.
    Matt Haub
  8. #38
    May 2009
    Brownsburg, IN
    158
    Caravan from where? Passing anywhere near Indy? What day/time? Sounds like a good idea if it can work.
  9. #39
    Aug 2005
    Paoli Indiana
    4,855
    Friday afternoon we will pass through indy if all goes as planned
  10. #40
    Aug 2005
    Paoli Indiana
    4,855
    Current state of things.. after installing a new fuel filter and a 255lph pump it still goes lean over 3.6v vmaf no matter what you do to the tune. Swapping rails and installing a new two hole regulator . My crude fuel pressure test never showed over 40psi under boost
  11. #41
    Aug 2005
    Paoli Indiana
    4,855
    If this for straightens up my lean condition I have to swap clutches next. This 500 mile spec 2 clutch is slipping a little smh
  12. #42
    Jul 2005
    Clarksville, TN
    1,885
    Myself and Col Glenn (XB-70) will be heading out from Clarksville Friday morning as well. Depending on peoples routes and times, we could all connect and have a great caravan up to WI!
    Smitty
    Venetian Blue 1995 5 Spd...............No ET
    Orange Crush Pearl 1995 Auto SC........TBD
    506.30 rwhp, 545.37tq
    Garage:http://www.sccoa.com/forums/garage_v..._vehicle&id=13
  13. #43
    Aug 2005
    Paoli Indiana
    4,855
    Quote Originally Posted by Quik95SC View Post
    Smitty
    Plans to meet up with mell butler and normL at the first rest stop north of indy should be early! Want to miss Chicago rush hour
  14. #44
    May 2009
    Brownsburg, IN
    158
    Just to make sure I'm on the same page...we're meeting at the rest stop in Thornton, IN on 65N?
    I once missed out on a first date with a woman I met at a race because we both didn't realize there were 2 Holiday Inns on the same road. She was waiting in the lobby at one while I was waiting at the other. lol Luckily we still managed to start seeing each other weeks later.
  15. #45
    Aug 2005
    Paoli Indiana
    4,855
    That's the plan I think its around milemarker 40something sorry I hadn't pmd you yet
  1. Shootout time! what do you have left to do?
    By davec73 in forum Non Technical Forum
    Last Post: 10-02-2017, 07:44 AM
  2. So what do you guys have left to do for the shootout???
    By Jacob_Royer in forum Non Technical Forum
    Last Post: 09-29-2016, 07:59 PM
  3. What do you have left to do for 2014 Shootout ?
    Last Post: 10-07-2014, 03:12 PM
  4. Shootout!!! What do you have left to do?!
    By DrFishbone in forum Non Technical Forum
    Last Post: 09-19-2011, 12:43 PM
  5. This is hilarious if you have time to read it all.
    Last Post: 04-30-2002, 08:39 AM
