Results 1 to 7 of 7
Thread: Starter Ignition Switch
    Feb 2016
    53
    Lately ive been having electrical problems with all of the interior lights in the car. I haven't been able to figure out what it is yet, I checked the fuse box under the dash and no power is going to some of the fuses. I looked at the starter ignition switch and noticed the harness wont plug all the way up in the switch, the weight of the harness and all the wires makes it not stay in there all the way. The starter ignition switch also has a small gap separating the two peices. My battery reads 14v when car runs so I don't think its completly failed yet. Could the switch be causing my light problems?Name:  20190814_214704.jpg
Size:  3.38 MBName:  20190814_214659.jpg
    May 2012
    Denver Area
    934
    Edit: You said interior lighting... good luck
    Salem OR
    7,423
    Replacing that switch is a no-brainer if it's been in service for a while, even if it doesn't fix your current issue. They are a common failure point, not expensive, and easy enough to swap out, you just need to have the correct torx bit. Search here for steps to install new.
    Otherwise (and according to a '90 EVTM), I'd want to know that the connections at the 60A fuse in the Power Dist. Box (near the battery) are clean, and the main headlight switch is healthy - look for white power under it with the cluster bezel removed, indicating internal wear/corrosion. I'd replace it if any question, but it's not as easy to find and fairly priced as the ignition switch, I think. Might try to remove it and give it a bath in spray electrical/contact cleaner.
    Feb 2016
    53
    Ill probably have someone help me remove the instrument cluster cover, im not good working with the clips. Ok ill buy a new starter ignition switch, but I want to glue it together to keep it from separating. Whats a good glue that will hold metal to plasic? Ill also clean up the connection to the fuses, and use electrical grease stuff they sell at the store.
    Salem OR
    7,423
    There is significant internal torque that would, in my opinion, work to eventually defeat any effort to glue the housing. If the thought of it coming open is a concern, I'd tie-wrap it instead.
    Jan 2010
    Bossier City, LA
    2,296
    This.
    Some big zip ties around will help relieve SOME Of the pressure on the pot metal ears.
    RwP
    Dallas, TX
    5,754
    This.
    RwP
    I'll vouch for that. I've got one thats been like that for longer than I can remember.
  1. Is my ignition switch shot? Help Please!
    By SilverCoupe in forum Technical Forum
    Last Post: 12-20-2003, 10:29 PM
  2. Where to buy screwdriver for the ignition switch?
    By Gears in forum Super Coupe Club of Ontario
    Last Post: 06-06-2003, 10:17 AM
  3. Ignition switch question
    By thunderbirdsc5 in forum Technical Forum
    Last Post: 04-20-2003, 09:55 AM
  4. ignition switch?
    By wellby440 in forum Technical Forum
    Last Post: 03-15-2003, 04:03 AM
  5. Anybody familiar with the ignition switch recall
    Last Post: 09-08-2002, 01:24 AM
