Results 1 to 2 of 2
Thread: Generic Ford A/C question
    May 2012
    Denver Area
    930
    So I know this is the SC site but I have a Ford A/C related question. My 2008 Escape has a leak whereby the refrigerant in the AC system will leak out completely in about 3 days. I've used a manifold set to draw major vacuum on the system and it holds for several days when its empty and under vacuum. My question is this - the A/C compressor has a bolt/fitting on it that was about a half turn loose. What is this bolt/fitting for and could it be part of my leak?
    Salem OR
    7,376
    What is this bolt/fitting for...
    Without photos that 'bolt' could be anything and not be a culprit.
    If it's actually a fitting, sure, any fitting could be suspected of leaking. If the system can hold a vacuum for several days and yet lose all charge in just a few days, that sounds like the valve isn't seating when the system is otherwise closed up and the hoses are disconnected. It wouldn't play a role when holding a vacuum... Have you replaced the schrader valves in the ports?
    Suggest you introduce a dye tracer and hunt w/a UV light.
  1. Ford Premium Audio Question
    By Scott D in forum Non Technical Forum
    Last Post: 07-31-2010, 12:41 AM
  2. Questioning quality for new (Rebuilt) Ford Engine
    By duanemyhre in forum Technical Forum
    Last Post: 06-26-2003, 04:57 PM
  3. wheel question (generic)
    By James Kanteraki in forum Technical Forum
    Last Post: 08-13-2002, 10:10 PM
  4. not an SC tech question, but a Ford tech question
    By platinumsc7 in forum Technical Forum
    Last Post: 08-01-2002, 05:40 AM
