Results 1 to 2 of 2
Thread: crank sensor replacement
    May 2012
    24
    during my diagnosis, pin 1 on my crank sensor is not blinking.
    i'm aware i'll be in need of an other one, however, what is the best way to get that thing out? i was doing some looking and some people have had luck getting it off without removing anything (saw a video on a XR7)
    also http://www.sccoa.com/articles/crankshaftsensor.php
    is the SCCOA article the best way to go? i already have belts off so i'm just getting a game plan going now.
    May 2012
    Denver Area
    934
    You can go in from underneath with a 6 inch extension and the correct socket - I'd suggest 1/4" drive tools. Yes its a pain but it can be done. I recently removed and replaced mine without issue. Be careful with the connector as you can damage the retaining clip pretty easily. There is a cover and the sensor. They are both secured by their own nuts. I think it's 8mm IIRC.
  1. tips on crank sensor replacement asap
    By Douglas Walker in forum Technical Forum
    Last Post: 07-09-2003, 01:42 AM
  2. crank sensor replacement
    By Zman in forum Technical Forum
    Last Post: 07-01-2003, 06:21 PM
  3. What Else Should I Do While I Get My Crank Sensor Replaced?
    By kennster in forum Super Coupe Club of Ontario
    Last Post: 09-05-2002, 06:32 AM
