Results 1 to 12 of 12
Thread: 94 gears fit a 90?
    Jan 2006
    Edmonton,Alberta,Canada
    444
    94 gears fit a 90?
    Considering a set of 327's, found some from, a 94. Would they be the same year to year?
    Jan 2010
    Bossier City, LA
    2,290
    Quote Originally Posted by spetz01 View Post
    8.8 3.27 gears are the same year to year, yes.
    What do you have in your car now?
    RwP
    Jan 2006
    444
    Just stock. Literally the only part of the car I haven’t changed.
    I’d like to just swap the whole rear end without doing the actual gear swap. That’s still possible? I guess I’m asking if the pumpkin is the same as well?
    Jan 2010
    Bossier City, LA
    2,290
    Just stock. Literally the only part of the car I havenít changed.
    So, manual or auto on your SC?
    RwP
    Franklin,Mass
    436
    Iíd like to just swap the whole rear end without doing the actual gear swap. Thatís still possible? I guess Iím asking if the pumpkin is the same as well?
    Yes, you can just swap out the pumpkins.
    Joe
    Jan 2006
    444
    She's a 5 spd. The car belongs to my father and law now, but I still get to play a bit lol...
    I'll be calling Bill today at SCP to line up gears and a rebuild kit? He has the option for the posi rearend, big bucks! Would that be worth it? Car's not raced or anything crazy like that.
    English, IN
    4,513
    Traction control cars with the automatic came with non-limited slip differentials, if I recall. As has been mentioned, they'll bolt in with no problem.
    Matt Haub
    Shootouts: '09 SS 1st | '10 Mod1 2nd | '11 Bracket 3rd | '12 Bracket 1st | 2013 | '14 Bracket 3rd | 2015 | '16 Bracket 1st & Mod2 2nd | '17 Spectator | '18 Freeze-Plug Champ
    Black '89 5spd - 281K miles, MPx, Alky-Inj ¶ 387rwhp, 438rwtq (new motor) ¶ Best 1/4mi:12.521, MPH:107.23mph (old motor)
    Jan 2010
    Bossier City, LA
    2,290
    What's the weather like where you are? I'm adding the Dana Trakloc LSD to my Dakota if I'm rebuilding the rear end this weekend (it's currently an open.)
    My Cougar has the LSD, and you've got it now; with 3.27s behind a M5R2, you'll want the LSD to keep from burning just one tire off on launch
    RwP
    Jan 2006
    444
    Sorry, thought I replied via phone earlier....
    It's a fair weather car, not year round up here at all. It would be nice though to launch hard when needed. Would the lsd help with all that wheel hop? Has new, non- adjustable tokico shocks and a 2" drop.
    And does anyone know roughly what this does to the RPM's at 60mph? I can't see it being overly excessive?
    Jul 2005
    Mississauga
    1,002
    It will change by 10%. 100kph indicated = 90kph actual. I changed the gear in the trans to correct that.
    Alan.
    Adrian, Michigan
    1,374
    If it's a five speed SC it came from the factory with LSD, POSI, or whatever you want to call it. Ford calls it Trac-Lok. Might be a good idea to rebuild it though.
    SCCoA Member # 490 since 1997
    1995 SC (five speed) [email protected]
    Best 60' 1.7489
    1994 SC (automatic) [email protected]
    Best 60' 1.8539 On a stock long block with bolt on's
    http://www.sccoa.com/forums/garage.p...ge_view&id=638
    Nov 2012
    Canton, GA
    327
    I replaced the whole pumpkin in my 1991 5-speed with one out of a 1990 automatic SC. I like it a little more than the way the factory had it (donít forget to change the speedometer gear ). Driving in 2nd gear almost feels like 1st gear in some cars Iíve been in. I was deducted some points on my driverís test for taking off in second gear when I was ďsupposedĒ to take off in 1st gear. I canít even put the car into 1st gear unless the car is practically at a dead stop (or less than 3 MPH).
  1. header info... wil 94 95 fit 90?
    By animalguy10 in forum Super Coupe Club of Ontario
    Last Post: 12-23-2012, 02:38 PM
  2. Will 94 SC Throttle body and/or odometer gauge fit a 90 SC
    By Rican3kgt in forum Non Technical Forum
    Last Post: 08-05-2007, 01:34 PM
  3. will 94-95 sc cobra hood fit a 90
    By fasttbird12 in forum Technical Forum
    Last Post: 01-09-2005, 01:52 PM
  4. do these gears fit a 90 sc
    Last Post: 12-07-2004, 03:16 PM
  5. Will the 95 auto tranny fit in 90 sc (auto)
    By white90sc in forum Technical Forum
    Last Post: 09-08-2002, 10:27 PM
