Results 1 to 4 of 4
Thread: Lowering a sc
    Nov 2019
    7
    Question Lowering a sc
    New to the SC ownership. Love the cars!!! This site has been super helpful
    Question: Is there a way to lower these cars while still maintaining the ride control feature? If so how and what's the best product to use(looking for 1-2 inches) if it's not possible without eliminating the ride control then whats the best way to go. Thanks so much for helping if you can.
    Salem OR
    7,309
    My '90 Anny is lowered (w/fatter rear sway bar/poly bushed end links) and still has ARC...I'm sure there are many more similar examples - is there something specific you've learned that prompts the question?
    You're just installing shorter springs, not changing the shocks, etc.
    See supercoupeperformance for new kits, your choice of drop:
    1.6"
    https://www.supercoupeperformance.co...t-set-of-4-508
    3/4"
    https://www.supercoupeperformance.co...t-set-of-4-507
    SCP should also have fresh spring cups if needed.
    Might want to check the for sale forums here for used, or place your own want-to-buy ad.
    Jul 2005
    Mississauga
    1,002
    Don't forget to change the rear sway bar end links if you put in shorter springs. You need to maintain the geometry of the sway bar or you will bend or break the end links.
    Alan
    Nov 2019
    7
    Thanks for the help!
    bushed end links
    1.6"
    3/4"
  1. Need Info On How I Can Lower My Sc
    By ROBSQUEZN in forum Technical Forum
    Last Post: 02-02-2005, 09:41 PM
  2. Lowering the SC
    By Stevie_B_SC in forum Non Technical Forum
    Last Post: 12-12-2004, 04:47 PM
  3. lowering 1990 SC
    By Matthew_solberg in forum Technical Forum
    Last Post: 06-21-2004, 07:41 AM
  4. Recommendations to lower my SC??
    By frontshadow in forum Technical Forum
    Last Post: 05-01-2003, 05:32 PM
  5. lowering my sc
    By lostsoul74 in forum New SC Owner Forum
    Last Post: 01-17-2003, 02:44 AM
