Results 1 to 9 of 9
Thread: so what are your plans for 2020 on your car?
    Milwaukee, Wisconsin
    3,495
    My two plans are to get some track time with my twin turbo 4.5 and see just how far into the CRAZY zone I can get. get the two step set and play with the bump in set up. With those two working it should be a fun time. Then it is on to the big block and start playing with some more power adder's.
    That should keep me quite busy for most of the summer....Rich
    Too many cars,too little time to drive them. Anything less than 500 cubes is a small block. If you slow down in life you will get run over..
    Nov 2012
    Canton, GA
    335
    I donít plan on doing much with my 1990 in Wisconsin, but I may try to find where my battery is draining and where rainwater is leaking in.
    For my 1993, I want to get it to being a reliable daily driver. Needs new tires, has a slow coolant leak that needs to get tracked down, and the shifter is really wobbly. I may touch up some paint scratches then it'll be nice enough to take to the local car shows.
    I want my 1991 to be my stunt-double. It will get an improved rear anti-sway bar, engine cradle brace, all its body panels reinstalled, a few other bolt-on upgrades and hopefully a good roll bar. Maybe an improved exhaust, 1992 gas tank, and bigger rotors.
    Salem OR
    7,307
    2020...for my '90 Anny:
    • Clay bar horizontal surfaces
    • Repair hole in rear bumper skin
    • Refresh seals iC tubes
    • Add wireless charging capability to center console lid
    • Buy/install late model pass. side exhaust manifold
    • " " wideband A/F meter
    • " " poly steering rack bushings
    • " " fresh neg. battery cable
    • " " fresh gas hood lifts
    • Try to attend more car shows than last year
    3,495
    got something for you
    Quote Originally Posted by Rick_Leuce View Post
    I have a late gas tank with a bigger fuel pump already installed that I could send down the road if you want it let me know....Rich
    Aug 2005
    Paoli Indiana
    4,854
    I want to finish my TVS kit and new fuel system and get it dialed in. Maybe build a Turbo kit for my five speed car
    93 SC Red Aod 4.2/2.3lwhipple 422rwhp 11.360
    2013 Shootout Bracket ET First Place
    2015 Shootout Car Show Honerable Mention
    2016 Shootout Mod-1 First Place
    2018 Shootout Pro Street Runner Up
    Coming soon new motor 2300 TVS etc..
    90 35th aod stock, 90 5 speed Bolton Build in progress
    May 2004
    Va. Beach,Va.
    7,136
    For starters just to start driving it some again..............
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    Jan 2003
    Woodbridge, VA
    5,240
    Get this baby in and running.Name:  20191211_190553.jpg
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    3,495
    if you need any info
    Quote Originally Posted by BLOWN38 View Post
    If you need anything feel free to get a hold of me. I got mine up and running with the twin turbo set up on it I did pick up a few ideas along the way so feel free to ask....Rich
    Jul 2003
    Ottawa, Ohio
    5,436
    Few things to get ready for Hot Rod Power Tour and maybe part of drag week. Fix cracked cylinder head, rear tires, exhaust, retune should about cover it.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
  1. Whats the sweet spot for caster on these cars?
    By HwyStar in forum Technical Forum
    Last Post: 03-24-2015, 11:46 AM
  2. What can I use for gasket on MP 85mm Throttle Body
    By Mike Manzo in forum Technical Forum
    Last Post: 03-19-2003, 01:53 AM
  3. What are you doing for your SC this weekend?
    By JAFO in forum Non Technical Forum
    Last Post: 02-28-2003, 02:43 AM
  4. What are you using for a clutch???
    Last Post: 11-05-2002, 09:51 PM
  5. Replies: 0
    Last Post: 10-19-2002, 01:17 PM
