Page 4 of 8 FirstFirst 12345678 LastLast
Results 46 to 60 of 106
Thread: Possibly bad tps need some help
  1. #46
    May 2018
    Irmo SC
    112
    The pic where you see my finger holding electrical tape that wire is the single wire and there is a butt connector underneath the tape
  2. #47
    7,308
    Quote Originally Posted by 35th View Post
    Good info, thanks. I'm pretty sure I know that tapped up wire is the lone pigtail (shieled ground) off the crank sensor.
    Are you familiar with EMI?
    I'm thinking a fresher unmolested front harness is in your future.
  3. #48
    May 2018
    Irmo SC
    112
    Not familiar with EMI would you mind attempting to explain?
  4. #49
    May 2018
    Irmo SC
    112
    Curious
    Not sure if you have the time or will but if you do I'd like to speak with you on the phone because I feel much more could be understood in a shorter amount of time so if you are willing my number is 8033614503 my name is Chris. If not it's more than understandable
  5. #50
    7,308
    Chris - happy to discuss over the phone, I'm on the West Coast/Oregon, and won't have time until Friday or Sat. evening, say 7 pm my time, or Sunday after 10 am. Let me know what works for you.
  6. #51
    May 2018
    Irmo SC
    112
    I work those days on call but by all means call just means I may not be at the car at that moment or I might be that's the beauty of being in call you never know anything...
  7. #52
    7,308
    Great, looking forward to talking w/you.
  8. #53
    May 2018
    Irmo SC
    112
    Sunday would probably be the best considering the time zones if that is OK with you?
  9. #54
    7,308
    Sure, let's try.
  10. #55
    May 2018
    Irmo SC
    112
    Did the fuel pressure test KOEOF 40lbs KEORUN 32lbs If you Rev the engine pressure goes up to aprox 50 after 15 mins hold time still at 39 so not a fuel pressure regulator is assume.
  11. #56
    May 2018
    Irmo SC
    112
    Fuel injectors are E9SE-B1B which I belive are stock
  12. #57
    May 2018
    Irmo SC
    112
    Ran some temp ground to the dis seemed to help but not certain haven't driven it far enough to say with certainty we will see as I drive it more often fixed a few other none engine issues
  13. #58
    May 2018
    Irmo SC
    112
    So took the car out again to grab some chicken wings 2.1 miles from home ran normal on the way there on the way back I gassed it a bit to see how it was running took off great let off the gas came to a stop made a left and it started severely bucking hard while using about 1500 rpm of throttle pulled into a parking lot as to not let it continue to buck noticed I had no tach whatsoever shut the car off waited about 1 or 2 minutes tried starting the car got a very awkward lobe with no start almost like a bad battery/starter when it tries to fire got a pop back through the exhaust not really a backfire but certainly an audible sound and no start let it sit 10 more minutes and it started no tach and was able to get it home half way home tach started working... Any clues or suggestions?
  14. #59
    7,308
    Sounds right for early SC, 30#
  15. #60
    7,308
    Normally means cam sensor and/or harness/wiring/connector issues.
    Have you tried starting and driving around with the cam sensor unplugged?
    Any codes right after?
  1. Possibly a new SC owner, need some help making up my mind
    By Steve-O in forum New SC Owner Forum
    Last Post: 10-29-2006, 08:30 PM
  2. Need Some Help Guys!
    By SickWhip in forum Super Coupe Club of Ontario
    Last Post: 03-14-2006, 10:00 AM
  3. not a sc ?..but need some help
    By tbirdsc22 in forum Non Technical Forum
    Last Post: 05-07-2002, 04:08 PM
  4. need some help guys
    By intercooled 89xr7 in forum Super Coupe Club of New Jersey
    Last Post: 04-02-2002, 10:39 PM
  5. Need some help
    By blkmojo in forum Super Coupe Club of Northern California
    Last Post: 10-01-2001, 06:53 PM
