Results 1 to 4 of 4
Thread: Unable to maintain idle
    Oct 2011
    79
    Hey guy,
    So this is more me just gathering ideas for this to test in the spring when I plan to take the car out of storage.
    This is my current standing with the car
    On my way to work the car started to have issues maintaining a proper air/fuel mixture. At red lights would go extremely lean 22.4 and under power extremely rich 9.3 but would hold 14.7 under load without trying to accelerate.
    After work the car would start, rev to 3000 then go lean again and struggle to idle before stalling out. Feathering the throttle would allow it to continue to run but it was rough.
    Mod list on the car is a little long but 70m maf 75m throttle body, custom intercooler and tubing, 60lb injectors, 255 fuel pump, cam, rockers, ported heads, ported late SC and coated rotors, 10% OD, QH and tune. Not going to list the rest as they should not have an impact on this problem. The car is also not going into protect as fan are not coming on with key on. Any suggestions I will be able to test in the spring.
    Madison, Ohio
    17,683
    Classic vacuum/boost leak symptoms. Check all post supercharger connections.
    Email me here.
    Oct 2011
    79
    Thanks for the reply Dave! This was one of the first things I was planning on checking when the snow melts. Game plan was to reseal all intercooler connection and check all vacuum/boost lines for cracks and splits. If this doesn't work I will be back for more things to check.
    Oct 2011
    79
    Ended up finding one of my intercooler clamps had wiggled off partly causing a leak. Corrected it and everything thing seems fine now. Thank you
  1. Car jumps to high idle (~1700 RPM)
    By johnw in forum Technical Forum
    Last Post: 12-01-2008, 11:48 AM
  2. Key unable to turn to Accessory Position
    By happo2000 in forum Technical Forum
    Last Post: 07-04-2005, 01:56 PM
  3. Unable to access SCCOA from my location?
    By Digitalchaos in forum Non Technical Forum
    Last Post: 05-09-2004, 04:56 PM
