So this is probably old hat for all of you by now. My rear brakes were WORN lemme tell you. I managed to figure out that the pistons needed to be screwed back in(this was new to me), but when I went to bleed the lines after having the bleeder screw out so the brake fluid didn't damage anything by being forced back through the lines, nothing came out. Went and did some searching here on sccoa, and for a 89-92 you're just supposed to turn the key to 'run' to let the accumulator pump run or something - is that accurate? Does that mean I have to start the engine? My car is currently up on jackstands and I'm hesitant to start the car because I don't want the starter torque to wobble it off the stands.
