Results 1 to 9 of 9
Thread: Which way does the inlet pipe nut need to spin to be taken off?
    Jul 2018
    Florida
    29
    Should I be pulling towards the bumper or pushing towards the windshield? Haynes manual just says "remove."
    Salem OR
    7,378
    Unless you know you need to, neither.
    If you're just pulling parts to get to what's under the supercharger, leave that nut alone. Remove the four bolts holding the hat/top to the supercharger, then the two nuts holding the pipe at the intercooler and lift the hat and pipe off as one assembly. Much easier and you don't have to re-align when going back together.
    Otherwise, as seen in the photo, pull to tighten (tool is backwards for that, I think you know), push to loosen/spin off. Position the tool accordingly. Good on you for having the right tool
    Torque is like 200 ft. lbs, so again, unless you know you need to break it there, might be easier to leave it alone.
    Jul 2018
    Florida
    29
    ... why didn't I think of that? That's going to make my life easier then. Thanks! Im trying to get to the headgaskets. It's a learning process :P
    Salem OR
    7,378
    Quote Originally Posted by FurryWrecker911 View Post
    I did mine last year, finally. Lots of work, but it also provides a chance to take care of so many ittle things that, on their own, wouldn't be worth the trouble.
    Stick with it, speak up if you need help along the way, good luck.
    Ken
    Nov 2012
    Canton, GA
    358
    I did my head gaskets last year without the special tool (I got one now, but haven't used it yet). I know the threaded collar is attached to the supercharger top, not the tube (I used a flathead screwdriver and a rubber mallet once many years ago ). But you can just take the tube and supercharger top off as one piece with a regular ratchet set.
    If you wanted, you could probably google pics of the Supercharger tube and see which way the threads are.
    Roanoke, Virginia
    3,371
    I notice you have the main belt off, hope you loosened the 4 bolts on the Jack shaft pulley first.
    You can take the majority of the top end off in large sections also to make what seems like a difficult process very simple.
    Top tube as 1 assembly as mentioned. I've even removed the supercharger assembly with the top tube still attached before (it's just heavy). Drivers side accessory bracket can be removed in its entirety by just pulling the power steering pulley and removing the bolts.
    Again ask if you have questions. It's not as scary as everyone says.
    -Tim
    Current Collection
    1995 Thunderbird SC - Auto
    1994 Thunderbird SC - 5spd
    May 2009
    Brownsburg, IN
    158
    Push toward the windshield. Now, if you end up needing to remove the beveled end of the top (not seen until the big nut is backed off), like if you needed to remove the nut from the top for paint or powder coat, that is a left hand thread. They do that so the beveled end does get loosened when tightening the big nut.
    Jul 2018
    Florida
    29
    Oh dear... ok I'm gonna ask, what's a Jack Shaft Pulley and what 4 bolts are you talking about?
    Jul 2004
    Hamilton NJ
    2,127
    Threads are reversed on the blower top if you need to get it off, turn to right to loosen, but like others said take off all one piece, the jackshaft is the pulley below the A/C compressor
    Tom Downs-member#2752
    MPX'd 90 SC Auto~bought Feb. 2012
    RIP MOM!!! I will always miss and think about you 4Ever! 1940-2018
    RIP Rexy boy!!!! Miss my dog 2006-2018
    http://www.sccoa.com/forums/garage_v...vehicle&id=424
  1. Where does the right O2 sensor's harness lead to?
    By AlanEdwards in forum Technical Forum
    Last Post: 05-16-2008, 07:54 PM
  2. Which was does the radiator flow?
    Last Post: 04-24-2005, 04:04 PM
  3. Replies: 3
    Last Post: 01-14-2005, 12:13 AM
  4. what does the big hex nut on the steering rack do?
    By nitrouspaul in forum Technical Forum
    Last Post: 05-31-2003, 02:51 PM
  5. Which way does it spin??
    Last Post: 11-03-2002, 01:50 AM
