Results 1 to 12 of 12
Thread: AC Freon Capacity?
    Jul 2004
    Indiana
    150
    AC Freon Capacity?
    Hello,
    I've searched the forums, and google but there was not any info on this ?.
    I believe the 90 Cougar XR7 was factory R12 at so many ozs.
    I believe the Cougar should be 38 ozs. of 134a, If incorrect let me know.
    Thanks!
    Jul 2005
    470
    Good evening
    Below is an old thread addressing R-12 capacity.
    http://www.sccoa.com/forums/showthre...ms-All-Engines
    Jul 2004
    Indiana
    150
    Thanks Sam, but I'm using 134a.
    Jul 2005
    470
    Good morning
    Maybe this thread is better?
    http://www.sccoa.com/forums/showthre...C-rebuild-tips
    Jul 2004
    Indiana
    150
    Nice thread.
    I read the whole thread and did not find where the compacity for 134a is!
    I'm not saying it's not there, I'm saying I did not see it.
    By the way I am blind in my right eye.
    Thanks!
    Jul 2005
    470
    Good afternoon
    Refer to post #1 step 6.
    Dallas, TX
    5,753
    32oz is the recommended amount. You won't really be able to push more than that in anyway.
    Jul 2004
    Indiana
    150
    Thanks TbirdSCFan!
    Apr 2012
    Dallas, TX
    463
    Ac rebuild
    6. Recharge the system: Do not add more than 90 % of the original R 12 charge.
    The Thunderbird SC AC system takes 40 ounces +/_ 2 ounces of R12 Freon.
    90% = 36 ounces= 2lb of Freon.
    Autozone and O'reilly, both have their own brand of freon 12 O.Z. cans. For a brand new system it is as good as the expensive other brand.
    Unfortunately, even with the manifold valve closed, every time you swap a can you will be opening the line letting a little bit of air in it. Once you are sure that your system is leak free (holds the vacuum), you may ask your local shop to vacuum your system again ( 45 minutes) with their pump (better CFM rating) and do this step for you. I did it myself and it still worked out though.
    I wrote this a long time ago. Let me know if it is no clear. May be I can try to reword it.
    Jul 2004
    Indiana
    150
    Thanks Falcon20x!
    Very good information!
    I take it that 36 oz is for 134a?
    Apr 2012
    Dallas, TX
    463
    Yes. The conversion is to 134a
    Jul 2004
    Indiana
    150
    Good to know!
    I use 4 x 12oz cans of 134a freon.
    The reason I use 4 is, I bleed the line real good after changing cans.
    Most of the time you never get all of the freon put of the can.
    The 4th can is not empty and its about half full.
    I watch the gauges high pressure side and low pressure side they will tell when it is full.
    Thanks!
  1. replacing AC freon; properly....
    By SuperCoupe007 in forum Technical Forum
    Last Post: 07-21-2005, 01:41 PM
  2. anyone need freon for old AC systems?
    By Scott-Atah in forum Super Coupe Club of Western Canada
    Last Post: 07-26-2002, 12:58 PM
  3. AC blower fan
    By smithmy in forum Technical Forum
    Last Post: 06-22-2002, 08:56 PM
  4. I need a AC coil
    By bbitner in forum Non Technical Forum
    Last Post: 05-06-2002, 09:53 PM
