Results 1 to 12 of 12
Thread: Anyone recognise this electrical Connector?
    Mar 2020
    6
    I am in the middle of doing head gaskets on my first SC, it's a 1989 and I cannot figure out what this electrical harness plugs into. It's attached to the fuel injector wiring.
    Jul 2005
    470
    Good afternoon
    Look underneath the driver side exhaust manifold. It is the connector going to the driver side oxygen sensor.
    Mar 2020
    6
    Quote Originally Posted by sam jones View Post
    Good afternoon
    Thanks so much. That was it. I have just one last thing, then I can fire it up. I cannot find the wire that plugs into the coil pack. Where does it run? Could I have set something on top of it?
    Jul 2005
    470
    Good afternoon
    Trace the DIS harness to find the connector. This harness connects to the following:
    1. DIS module.
    2. Crank sensor.
    3. Cam sensor.
    4. Shield wire connectors
    5. Engine harness
    6. Ignition coil pack.
    7. Radio nose suppressor.
    8. Ignition jumper plug.
    See image below.
    https://www.google.com/aclk?sa=l&ai=..._MQvhd6BAgBEDE
    Mar 2020
    6
    Good afternoon
    1. DIS module.
    2. Crank sensor.
    3. Cam sensor.
    5. Engine harness
    See image below.
    Thanks. I found it soon after I posted. I was just being an idiot. Went in to get some water, and there it was. I just overlooked it for like 25 minutes.
    Started the car, and it ran. So I'm happy. But about 20 minutes later it started shooting steam out the exhaust and running very poorly. Guess it's back to the drawing board.
    Jul 2004
    Hamilton NJ
    2,129
    Quote Originally Posted by Jroy000 View Post
    Sounds like the head gaskets are blown! Common issue
    Tom Downs-member#2752
    MPX'd 90 SC Auto~bought Feb. 2012
    RIP MOM!!! I will always miss and think about you 4Ever! 1940-2018
    RIP Rexy boy!!!! Miss my dog 2006-2018
    http://www.sccoa.com/forums/garage_v...vehicle&id=424
    Jul 2004
    Hamilton NJ
    2,129
    Nevermind, read your first post again...
    Mar 2020
    6
    Ok, one last connector you can help with. What is this?
    Also I bought some "head seal" liquid. Figured it was a free car. And I have nothing to lose. Thing sealed right up and runs and drives. I think it has a little vaccume leak now. But I'm fixing some other problems in the mean time.
    Salem OR
    7,382
    Since the MAF connector is in order, it can only be one other thing in that area - the level sensor for the coolant expansion tank, which isn't installed, so...still have that tank and sensor? I'd not run the engine to temp/cooldown without, BTW.
    If the car has a VMM, is the low coolant light lit?
    Mar 2020
    6
    Sorry for such a long absence....
    It's been really Rainy and cold here in Ohio. And I don't have a garage. The radiator overflow is in the trunk. I should've been able to figure that out. Lol I just didn't put it back because the water that I added never went into the radiator. Seemed to me like it was just an overflow tank. No low coolant light with it disconnected.
    No overheating problems currently.
    I have one more plug that I can't figure out. But the car runs and drives fine. I think, I called a friend that has driven a few of these, and he was not impressed. He says he thinks it has a vacume leak. It's really sluggish. And I hear a clicking sound coming from behind the passenger headlight. Sort of sounds like a spark plug, it comes and goes. Any ideas?
    Salem OR
    7,382
    That tank is not for overflow - it is for 'expansion', and an integral component, so again, without which the cooling system will not function correctly across heat/cool down cycles. Air in the cooling system will raise heck with the ECT, as one example, which leads to unreliable inputs the computer uses to decide air/fuel ratios.
    There is only one thing behind the pass. side headlight that can make clicking noises - the IRCM. On an '89 SC, it controls the cooling fan speeds, the A/C clutch and EEC power.
    Lots of things could make it run 'sluggish'. Vacuum leaks can manifest in many ways, depending on if they are small or large, and where they are. Do a visual on all the rubber lines you can spot and throw a wrench on the nuts for all the intercooler tube clamps.
    Pull the codes to see what turns up there.
    Might need to pull the spark plugs to be sure they survived the head gasket issue.
    See if the fluid in the oil pan still resembles oil...coolant makes a lousy lube and might be the bearings/rings are trashed, dragging away power, leading to the 'sluggish' feeling.
    Consider doing a compression test.
    Check the brakes to see if they are dragging.
    If auto trans, confirm the TV cable bushing is intact and the cable is adjusted properly.
    Confirm the air filter is clean/clear.
    Check fuel pressure at the rail...report what you find at idle, and under boost.
    Confirm the throttle plate is opening all the way when the gas pedal is pressed to the floor.
    Oct 2019
    4
    When I suffered from vacuum leaks I checked for them by spraying quick, short flicks of starting fluid around the engine bay -- anywhere that could have a bad seal. If any starting fluid gets pulled in by vacuum the engine will rev up by itself and you'll know that there is a leak. Just be really careful, since you're doing this when the car is running you should keep your distance in case something sparks the fluid.
    If you ran the car with contaminated oil it's possible that it damaged some of the lifters and moving parts in the engine, but when my car blew the gasket the oil was never visibly contaminated.
  1. can anyone identify this connector
    By ghostryder in forum Technical Forum
    Last Post: 10-30-2013, 04:46 PM
  2. Relocate oil filter...anyone done this?
    By z90sc in forum Technical Forum
    Last Post: 08-20-2002, 03:35 AM
  3. WOW, anyone see this?!
    By TBKHomeworld in forum Super Coupe Club of Southern California
    Last Post: 05-11-2002, 01:41 AM
  4. Has anyone tried this. (Intercooler tubes cooling)
    By Joey OKC in forum Non Technical Forum
    Last Post: 05-10-2002, 03:26 PM
  5. Is anyone from this board going to the V6 Event?????
    By Tazmision89 in forum Super Coupe Club of Greater New York
    Last Post: 06-10-2001, 10:36 PM
