Results 1 to 7 of 7
Thread: 2020 BBF/T56 . . . Back to work
    Sep 2002
    SE CT
    732
    https://imgur.com/gallery/LouLsbP
    Had to take a bunch of wrench time off due to health reasons. Still not back 100%, probably never, but working on getting as good as I can.
    Finally got enough $$ to move forward some. New Ford Performance SCJ heads came in along with the Blue Thunder intake and Holley lower plenum. Found some bolts to attach the heads to the intake (not on engine) so I could start working on injector placement. Local machine shop is on shorter hours and I get up late morning. Need to get an estimate on block work. Then see what is left over. To stroke or not. Got a line on a Lunati cam kit, custom flywheel with GM clutch set (for LS1 T56). Still need to pick out a fuel pump and bigger fuel line. ¬—¬— HEY RICH, what size line should I go with? putting together a shopping list for: parts to build motor mounts. Manifolds/Headers. Then the accessories drive. I think that¬’s enough for now.
    MikeH
    Milwaukee, Wisconsin
    3,499
    here is what I did on my turbo svo.
    Quote Originally Posted by talonhead View Post
    Finally got enough $$ to move forward some. New Ford Performance SCJ heads came in along with the Blue Thunder intake and Holley lower plenum. Found some bolts to attach the heads to the intake (not on engine) so I could start working on injector placement. Local machine shop is on shorter hours and I get up late morning. Need to get an estimate on block work. Then see what is left over. To stroke or not. Got a line on a Lunati cam kit, custom flywheel with GM clutch set (for LS1 T56). Still need to pick out a fuel pump and bigger fuel line. —— HEY RICH, what size line should I go with? putting together a shopping list for: parts to build motor mounts. Manifolds/Headers. Then the accessories drive. I think that’s enough for now.
    MikeH
    I went with an6 and an8 for my fuel and return. hope that helps you out....rich
    Too many cars,too little time to drive them. Anything less than 500 cubes is a small block. If you slow down in life you will get run over..
    Sep 2002
    SE CT
    732
    Thanks Rich! Need to spec an EFI pump to put in at the same time I drop the tank for the fuel lines.
    MikeH
    3,499
    some ideas
    MikeH
    I went with an aeromotive fuel tank with a 2000 pump. I also went with the fitech carb set up. This was easy to put on, simple to set up and fired off the first time we hit the key.. Just some ideas for you.....Rich
    Sep 2002
    SE CT
    732
    Updates pics of top end bbf
    https://imgur.com/gallery/LouLsbP Top end parts- heads, intake, plenum
    https://imgur.com/a/uLFK1MB Starting BT intake modification to efi
    Received my rolls of copper-nickel fuel lines. Working on car when itís late or raining.
    Otherwise, Iím at work or working on wifeís truck replacing brake lines, hoses, and master cylinder. Just got all of the hard lines out tonight. Wasnít all that hard, just trying to not cut them or mangle them so I have an idea of installing the new ones.
    MikeH
    Sep 2002
    SE CT
    732
    More progress
    http://https://imgur.com/gallery/ZXUMdfJ
    More pics. All runners drilled. Now to set up the jig to set in the bungs.
    MikeH
    Jan 2003
    Woodbridge, VA
    5,250
    Looks bitchin!
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
  1. Im back/ ready to work on my sc
    By shawpdx1 in forum Technical Forum
    Last Post: 03-01-2009, 04:48 PM
  2. Got me a 1994 SC.. needs some work.. nursing her back to health...
    By jamesgangel in forum Non Technical Forum
    Last Post: 03-03-2005, 08:50 PM
  3. Lets get back to being a club
    By Jim Demmitt Jr in forum Super Coupe Club of Northern California
    Last Post: 05-27-2002, 01:19 PM
  4. next meeting -- back to the west end
    By fast Ed N in forum Super Coupe Club of Ontario
    Last Post: 05-15-2002, 06:33 PM
