Thread: Simultaneously installing engine front cover with camshaft synchronizer?
    Aug 2017
    2
    When I removed the engine front cover to replace a leaky gasket on my 94 SC, the camshaft synchronizer came off as part of the cover. My question is, “Should I install the new synchronizer simultaneously with the cover, or do I wait until the cover is on and sealed before I install and adjust the new camshaft synchronizer? I’m inclined to think that I have to wait until the cover is on due to the many helpful threads I have seen on installing and adjusting the synchronizer.
    21,122
    Remove cam sensor syncro stalk and reinstall separate from the timing cover. See link below for instructions on installing the stalk.
    http://www.sccoa.com/forums/showthre...+stalk+install
    Aug 2017
    2
    Thanks!
    Very helpful!
  1. Used 89-93 engine front cover
    By tydlwavs in forum Parts for Sale
    Last Post: 10-29-2009, 06:03 PM
  2. 1990 SC engine front cover
    Last Post: 04-10-2008, 02:48 PM
  3. Installing engine with longtubes attached.
    By V8Supercoupe in forum Non Technical Forum
    Last Post: 08-15-2003, 04:53 PM
  4. Removing Engine Front Cover
    By Jimmy 2Coupes in forum Technical Forum
    Last Post: 02-09-2003, 12:08 AM
