FurryWrecker911
I have a problem, and I'm hoping it's a case of me just undoing the wrong fastener. I have a 1989 SC, and I have the 4 torx screws and fuel injectors nice and loose, but the rails are stuck at the fuel pressure regulator. Haynes manual is only good for the V8 and non-supercharged V6, and it says it's just a bolt holding it to the back of the block. Well, I found a 13 mm nut on a stud in the same general area, and undid that to no avail. I came on here to see people saying it's a 15mm bolt which I could not find while I was down in the garage.
Alright so what's the deal, did I undo the wrong fastener or were the 89s special and used a nut and stud instead?
