Results 1 to 15 of 20
Thread: AC reinstalled on my 91 SC along with a couple more upgrades....
    21,173
    Switched from a MP FMIC with AC deleted to a traditional FMIC with full width Griffin radiator, full width condenser and OEM style fan....all for a 97 Thunderbird. To make room for the new IC tube routing, the battery was relocated to the trunk. While the car was apart, the stock timing chain was also upgraded to a double roller billet set from SCU. Good thing because Dave found that my chain tensioner was broken and cam sprocket was badly worn. All the old braided stainless rubber fuel lines that were leaking gas fumes in my garage, were replaced with new PTFE braided stainless lines.
    After getting the car on the dyno (aka Dream Crusher) we found that air charge temps are much lower (120 F max) and boost is down significantly. Even with my smaller blower pulley (3.375") the most boost it will make now is 19.5 PSI. With the old MP setup it used to make 22 PSI on the large pulley (3.500"), and about 23.5 with the smaller pulley so it's down about 2.5 psi and 30 rwhp on pump gas tune and 4 psi on race tune. Since there are no boost leaks and only about a 2 psi pressure drop on the new inter-cooler, we are assuming the drop in boost is because because of greater inter cooler efficiency but not really sure. It still pulled 450 rwhp on pump gas tune with no corrections for the 80 degree weather and previous stumbles and misfires are gone.
    Car is much more pleasant to drive with cold AC blowing and car not overheating. Planning to overdrive the blower another 6.3 % on pump gas tune and 10% on race tune to get the boost and power back up to normal levels. Here is a video and a few pictures of new stuff. Big THANKS to David Dalke at SCU inc for a job well done.
    Name:  Engine bay July 2020.jpg
    Name:  Double roller timing set.jpg
    Name:  Dual pump PTFE fuel lines.jpg
    Sep 2004
    Herrin Illinois
    3,490
    Looks great David. Your going to enjoy the ptfe lines man lol. Im in the middle of redoing my exhaust right now. My rborla resonater cam apart inside. My car with a 3.5 blower pulley and no overdrive only makes around 18 tops right now but i figure while im breaking the new 4.2 in its probably better anyway lol.
    member #2488
    Nov 2016
    PNW
    305
    Outstanding build! Thanks for the update.
    Creighton
    21,173
    Parts to spin the 2.3 Whipple a little faster have arrived.
    Name:  MP 10% OD crank anodized.jpg
    Aug 2004
    KSRQ
    5,223
    Glad to hear you caught that cheap piece of plastic before it broke! Some guys have all the luck
    Another great looking job by Dave, and the car sounds as good as ever. What a great idea for moving cooler air through the system!
    21,173
    Quote Originally Posted by Ira R. View Post
    Yes I'm very lucky the timing chain didn't break. Dave said it's the worst he has seen and couldn't believe it was still running. Here are a few pictures.
    Name:  Timing chain tensioner 1.jpg
    Name:  Timing chain tensioner 2.jpg
    Name:  Timing chain tensioner 3.jpg
    21,173
    Removed the UD pulley set and installed 10% OD crank pulley and stock size WP and ALT pulleys and switched supercharger pulley from 3.375" to 3.500". This increased overdrive by 6.3% and should get it back to about the same power it was making with the MP FMIC on the pump gas tune. I'll swap to the 3.375 pulley if using the race gas tune. Here is how it looks now with pulleys reconfigured for street tune. Haven't had a chance to measure how much more boost it's making, but it feels a little stronger.
    Name:  Engine bay July 2020 with 10% OD crank.jpg
    Sep 2004
    Herrin Illinois
    3,490
    Me too
    Thats exactly what happened to my current motor before i got it and rebuilt it. Mine has one of the double rollers as well.
    member #2488
    Boston, MA
    7,534
    I am curious about this tensioner failures. Is valve floating or bouncing of re limiters causing this? Looks like some sort of abuse is in play here. Were these Chinese replacement parts or OE?
    21,173
    Ricardo,
    I'm told it's because of high rpm, which in this case means routinely exceeding 6000 rpm. The timing set shown in pictures was all new parts that were included in the 4.2 engine build that SCU did for me in 2009. I don't think SCU had a double roller timing set at that time and the only option was Morana. I have seen a lot of problems with them, so I'm sure I would have insisted on the stock timing chain especially since failures were pretty much unheard of. Anyhow, I exceeded 6000 rpms pretty much every time I drove the car and when racing it my shift point was 6500 and the rev limiter was 6800. If doing a burnout I would usually hit the rev limiter at least once. So I'm surprised it lasted as long as it did.
    Boston, MA
    7,534
    Ok just trying to get an idea how pressing it is and it’s root, I know your is pushed hard, but on my car I sometimes forget I can go past 6000. The redline is at 5500 or so on my car and I for some silly reason short shift it. Maybe cause I would be breaking the speed limits by then so I shift up. I don’t think I hit the rev limiter before. It’s pretty high up, I have valve float way before the rev limiter. My car is done about 6,300 so I tend not to push it that high unless on the dyno, the shift light is around there 6300 to 6500 i don’t see it light up often. The car feels like it’s about to explode that high up, the Coyote I can do 7500 and it’s pretty smooth, they break oil pump gears when hitting rev limiters. I set it at 8000 to prevent it.
    I’ll put it on my wish list. But more back burner wish list.
    21,173
    Ok just trying to get an idea how pressing it is and itís root, I know your is pushed hard, but on my car I sometimes forget I can go past 6000. The redline is at 5500 or so on my car and I for some silly reason short shift it. Maybe cause I would be breaking the speed limits by then so I shift up. I donít think I hit the rev limiter before. Itís pretty high up, I have valve float way before the rev limiter. My car is done about 6,300 so I tend not to push it that high unless on the dyno, the shift light is around there 6300 to 6500 i donít see it light up often. The car feels like itís about to explode that high up, the Coyote I can do 7500 and itís pretty smooth, they break oil pump gears when hitting rev limiters. I set it at 8000 to prevent it.
    Iíll put it on my wish list. But more back burner wish list.
    Ricardo,
    I wasn't planning to do anything with the timing chain on this round of upgrades, until seeing a post Dave Dalke made about several recent timing chain failures on SC motors of similar power level. Very glad that I did, because I'd be fixing a lot more stuff if the chain broke. Now I'm a little more mindful of RPM, but I don't imagine my driving habits will change much, so I'm not bothering to change the shift light settings.
    Jul 2005
    Mississauga
    1,011
    Dave;
    I am glad you got a better result from your tensioner failure than I did.
    I ended up on the side of the road with a dead car and ultimately had to rebuild (thanks, Dave) my whole engine.
    Alan
    Feb 2003
    Tinton Falls, NJ
    1,691
    At what rpm should the factory setup be a concern?
    Jul 2003
    Ottawa, Ohio
    5,462
    I've broken 2 of the tensioners, first one bent all the valves and well the second found after removing engine to be replaced.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell - SOLD Aug. 2020 -
    11.676 @ 121.35 mph
    506hp/478tq
  1. Replies: 2
    Last Post: 05-05-2020, 10:38 PM
  2. Road trip to SCU with my 91 SC
    By David Neibert in forum Non Technical Forum
    Last Post: 09-25-2017, 02:39 PM
  3. brakes on my 91 sc
    By daxl350 in forum Technical Forum
    Last Post: 06-10-2006, 10:25 AM
  4. Can I use 98 SN95 spindles on my 91 SC
    By jettburn in forum Technical Forum
    Last Post: 05-01-2006, 11:48 AM
  5. Need Help On Wiring On My 91 Sc
    By PACKIN86 in forum Technical Forum
    Last Post: 04-25-2003, 03:05 AM
