Anyone with the late style gas tank, heat shields and straps Also looking for a mor aggressive cam than I put in my 4.2 stroker when I built it Current cam is@ @.499 .497 smooth idle, cam is suppost to be a @2500-4500rpm middle range. Im swapping out the old close ratio M5R2 for a 94 Wide ratio and a 3.73 chunk. Late style gas tank needed.Fuel pump doesn't matter I am putting in a 255GPH to feed the 40lb injectors, I'm going to need a good tuner up here in Michigan, livonia area, I have a 3 tune SCT chip to install. And a Launch , No lift Shift controller, just in case It sees some strip action when done?I could also use some 1.8 ratio roller rockers I have 12 Ford Motor sport 1.73 ratio rollers right now
ANY one LMK .shipping to 48185 Westland ,MI.
Bob
Bob
