Results 1 to 6 of 6
Thread: Please Help
    Please Help
    I have recently replaced the head gaskets on my 1995 Black Automatic SuperCoupe. The car was running, idling, no vacuum leaks or anything (major accomplishment considering that I have never done anything to that caliber to a car). All of a sudden the car died and lost its spark, I have replaced the coil, the cam sensor, the ICM and Iím still getting the same result, if anyone can point me in the right direction I would greatly appreciate it! I just want to drive my car again.
    Thank you again for any advice and/or input!
    Jul 2005
    482
    Good evening
    Suggest you ask this question in the technical forum.
    Apr 2007
    New Orleans, LA
    1,975
    no spark is easy
    first check the crank sensor and make sure its not messed up nor the wiring messed up or frayed
    sounds like you lost the crank trigger input
    I have replaced the cam sensor, the crank sensor, the crank sensor connector, the coil, the ICM. So I wish it was that ďeasyĒ but Iím at a complete loss here
    May 2018
    Irmo SC
    167
    I know it sounds silly
    Check the ground wire near the battery if it is disconnected or there is alot of corrosion that's the ground to your ecm
    Salem OR
    7,506
    This is for an '89, but it may still provide some help:
    http://mnharms.com/tutorials/disnostart/
    Good luck.
  1. Auto Trans experts...please help
    By Tubeamp in forum Super Coupe Club of Ontario
    Last Post: 12-11-2009, 12:11 AM
  2. Need Best prices on some ford parts - please help
    By white91sc in forum Non Technical Forum
    Last Post: 05-27-2002, 09:53 PM
  3. Looking at 90 SC Please Help!!!!!!!!
    By Soon2BeSC in forum Non Technical Forum
    Last Post: 05-03-2002, 09:17 PM
  4. PLEASE HELP!!!
    By YoshiRSC90 in forum Super Coupe Club of New Jersey
    Last Post: 01-26-2002, 07:31 PM
  5. CHIP FOR MY SC....... PLEASE HELP
    By 91TBIRDSCX766DM6 in forum Super Coupe Club of Greater New York
    Last Post: 08-27-2001, 06:29 PM
