Concensus on Valve Springs?
Pro_usa1776
I've read most of the valve spring discussions on the forum. It seems that the answer to what type of valve springs should be used with the CAM listed below are all over the place. I was going to use COMP Cam 942-12 Valve Springs. I measured the Valve installed height on all the valves on 1-3 cylinders and the avg = 1.654"
COMP Cam 44-701-9
ADV Duration 259 (Intake) 271 (Exhaust)
Duration @ 204 (intake) 216 (Exhaust) Lobe Sep: 115.0
Valve lift: 480 (Intake and Exhaust)
I'm going to give Comp Cam a call tomorrow and go from there and see what they have to say, unless someone knows where I can get new keepers to fit beehive springs?
