Results 1 to 4 of 4
Thread: part number
    Feb 2003
    NE PA
    508
    part number
    Anyone have a part number for the rear upper control arm nut (frame side)? I know the bolt's discontinued but I was wondering if the nut has been too.
    Thanks,
    Mike
    Apr 2004
    48183
    3,935
    N-805470-S is what im coming up with for the nut
    N-805678-s160 for the bolt
    Both do not show as good part numbers anymore. They could very well have been replaced with a different number. The bolt spec says itís a m12x110.5
    Oct 2018
    Nova Scotia, Canada
    156
    Quote Originally Posted by TwoToneThunder View Post
    McMaster-Carr stocks a M12x110 in 10.9 grade. https://www.mcmaster.com/screws/syst...ss~class-10-9/
    They should have a selection of nuts to fit the bolt as well. https://www.mcmaster.com/nuts/system...lass~class-10/
    Feb 2003
    NE PA
    508
    Thanks guys. I know the nut is 12mm x 1.75. I found a 10.9 replacement at a local hardware store. I was just hoping to locate an OEM nut.
    Mike
  1. Need part number for TV cable brass bushing and cotter pin
    Last Post: 07-18-2002, 12:43 AM
  2. Part number?
    By kbaker2 in forum Technical Forum
    Last Post: 07-14-2002, 03:43 PM
  3. 89-92 ABS relay part numbers
    By fast Ed in forum Super Coupe Club of Ontario
    Last Post: 07-14-2002, 05:12 AM
  4. MagnaFlow Resonator...Which part number???
    By cudaz101 in forum Technical Forum
    Last Post: 07-13-2002, 03:42 AM
  5. Search is down; Part Numbers needed
    By pastera in forum Technical Forum
    Last Post: 06-24-2002, 11:02 AM
