Results 1 to 4 of 4
Thread: Oil pressure gauge faulty reading
    Jun 2017
    Sweden
    63
    The oil pressure gauge on my 91 SC is reading too low. I have tested it by shorting the wire from the sender but is moves just shy of L and barely within the marking for normal. Oil pÄressure sender is new and oil pressure is checked with mechanical gauge and it's ok.I have the cluster out but don't know how to check the gauge. Any thoughts on how to test it?
    Oct 2018
    Nova Scotia, Canada
    162
    Jun 2017
    Sweden
    63
    Thanks for the input but problem solved. It was the circutboard to the right of the cluster that was not entirely in place and the wire from the oil pressure sending unit that was faulty. Replaced it with a new wire and everyting works fine.
    Jun 2017
    Sweden
    63
    Update
    Someone had replaced the instrument cluster with a cluster having the 20 ohm resistor on back thr oil pressure gauge. Turned out the sending wire also had the resistor in it so I bypassed the resistor on back of the cluster, as it was easier, and now it works as supposed to.
  1. No reading on Oil Pressure gauge
    By Sam Woodson in forum Technical Forum
    Last Post: 03-12-2006, 10:41 PM
  2. Oil Pressure Gauge reading low
    By derekhay316 in forum Technical Forum
    Last Post: 06-04-2003, 11:03 PM
  3. Why does my oil pressure gauge not move?
    By blkthndr in forum FAQ Forum
    Last Post: 10-28-2002, 07:50 PM
  4. Oil pressure gauge modification
    By SCCOA5 in forum Technical Forum
    Last Post: 09-16-2002, 09:10 PM
  5. Oil Pressure Gauge Conversion Time!
    By JimGravelle in forum Super Coupe Club of Ontario
    Last Post: 09-16-2002, 04:46 PM
