Cruise control
thunderbird89sc
Ok so its been a while since it worked, the last time it worked was when i put in a new brake light switch, and it didnt work later that day, i was wondering what could be wrong that is making it not work, im not even sure if there is a fuse for it or not, i checked under the horn cover and all the wires are good, any ideas would be great,
I would be lost with out you guys
vacuum dump
if you put in a new brake light switch ..you most likely messed up the vacuum dump line above the switch on the brake peddal and you need to readjust it so the switch is open and when you touch the brake peddal it closes ..had same problem after changing my abs pump ...
